Pulled codes on my '95 f-150 302 - trying to solve a rough, surging idle.
Codes
koeo - #111 - No problems, cm - #172 - Bank #1 lean
koer - #211 - Thermactor air system inoperable during test
#311 - Can't control idle during test - low RPM check
I replaced the tps and set voltage.
Replaced IAC - with new IAC diconnected, engine still idles level??? Bad part??
What would be the obvious things to look for based on the codes?
you have me stumped on this one. some times you need to adjust the IAC might try that. also have you checked out the koer - #211 - Thermactor air system inoperable during test. what did you find there.
I am still thinking on this one so keep bumping it up. there are guys way smarter than I AND THEY ARE PROBABLY STILL THINKING ALSO
