Aerostar Ford Aerostar
ac hose assembly
Old Mar 31, 2007 | 11:27 AM
silan's Avatar
silan
ac hose assembly
We all know that Ford's engineers were lazy when they designed the ac manifold hoses/routing (the two hoses that attach to the back of the compressor); the rubber sections (where they are crimped to metal) are either touching a sheet metal screw near the grill for the top one, while the bottom one sits on top of the rack and pinion shaft. Needless to say, my bottom hose has worn through and in need of replacement. I know I need the spring lock release tool to disconnect the couplers... Has anyone attempted to remove the hose assembly from the compressor? It is held on by one nut, but what are the chances of fitting my hand in there, and through which method?
Old Mar 31, 2007 | 11:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When you remove a/c hoses, you lose the (very expensive) R-12 Freon. If the hoses are worn through, and the R-12 Freon is already gone, the system must be evacuated by a garage that has the proper equipment. NAPA and most A/C shops can make new hoses from your old sample. Ford dealers can too.
Old Mar 31, 2007 | 12:01 PM
silan's Avatar
silan
Thanks for the quick reply.
I have converted to R-14 already. I'm more interested in the labor aspects of this; I'm wondering if this will be akin to the "infamous sixth spark plug removal"?
Woops, I forgot to mention that I have a 92 3.0
Old Mar 31, 2007 | 09:11 PM
silan's Avatar
silan
For the record, I jacked up the van on the passenger's side and was able to put a 10mm with extension to remove the hose housing from the compressor. Now to get the hose and finish the job!
BTW, from my vantage point behind the passenger A-frame, it seems that all the right hand spark plugs are pretty accesable with a socket and wrench. I will post this on the today's "last spark plug--arghhh".
Old Mar 31, 2007 | 11:16 PM
krankshaft's Avatar
krankshaft
Be sure to replace the O-rings on the back of the compressor with R134 compatable ones they are green in color. The spring lock removal tools are very cheap I got mine at Autozone you only need them to remove the hoses. They simply press on during installation.
Also I hope you changed the accumulator otherwise your new hoses can corrode since the accumulator removes moisture and when the dessicant eventually gets saturated this moisture mixes with the refrigerant and creates acid that attacks all of the metal parts.
75_92_95
Jul 22, 2019 11:49 AM
sfc2001
Jul 19, 2017 10:40 PM
bleudia
Aerostar
22
Mar 6, 2017 02:59 PM
mlandrum51F1
1947 and Older Ford Trucks
Sep 25, 2016 11:13 PM
T18skyguy
Jun 5, 2010 06:50 PM
