replace a/c compressor - 99 Expedition
Jumpered the cycle switch and determined it was low pressure situation -- took to dealer, who recharged/diagnosed leak situation. Compressor oil leak at front seal (needs replacement) and refrigerant leak at manifold hose assembly.
However - compressor running nice and quiet, after recharge, no problems, silent operation. Couple questions:
1. Ford manual says no need to replace accumulator unless there is evidence of compressor failure (which mine hasn't yet) -- is that 'evidence' trash in the orifice tube? If so, where precisely is it? I know it's in one of the tube assemblies, but can't visualize the location from the diagrams.
2. Since my compressor hadn't failed, still running quiet/smooth, can I just replace that and the leaky hose assembly and be done w/it?
3. Is this a job that's beyond the moderately skilled garage mechanic? I handle most of my own jobs with exception of heavy engine (i.e., heads, etc) but have never attempted a/c-related due to the refrigerant portion of this job. I'm sure I can obtain the proper vacuum equipment somehow, if it's something that's not too overly complicated...
Thanks for any insight... Dealer quoted $1250+ for changeout of compressor, accumulator, fixed tube assembly and manifold... Would like to handle myself if at all possible.
Thanks folks,
Scott
