Limited Slip
Old Mar 31, 2007 | 12:37 AM
dynamis5's Avatar
dynamis5
Limited Slip
Hey guys..
Was testing out my 4x4 the other week.. Just getting to know the truck. I was on an icy patch and accelerated (not hard, but not soft either). My back end really came over to my left. I tried it a few times and the same thing happened. The groud was even, so i wasn't quite sure why this was happening. I thought that limited slip is supposed to keep you straigther then an open diff.
I'm new to this stuff, so my facts may be a bit off.
Thanks guys.
Old Mar 31, 2007 | 06:04 AM
phil6608's Avatar
phil6608
With an open dif it will go straighter. I have a limited slip and when both tires start spinning it's very hard to keep her straight!
My truck will go sideways on dry pavement at a 30 MPH roll,,lol
Old Mar 31, 2007 | 07:41 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
an open diff usually has one non-powered tire while the other tire is under power and spinning. this non-powered tire maintains your trucks position.
the posi allows both tires to spin. any inertia you have will make the rear of the truck move from side to side since there is no anchor point like a open diff has
Old Apr 1, 2007 | 11:00 AM
osbornk's Avatar
osbornk
True. If you are on a slope, the rear will slide down the hill and if you are turning, you will learn what race car drivers refer to as "loose".
Old Apr 1, 2007 | 11:40 AM
dynamis5's Avatar
dynamis5
So, what is the real benefit of limited slip? Would it be just for when you get stuck?
Old Apr 1, 2007 | 11:55 AM
screwy's Avatar
screwy
Traction. It may be more prone to sliding around, but it’s less prone to getting stuck.
Old Apr 1, 2007 | 11:56 AM
phil6608's Avatar
phil6608
It's good for in the rain, on slippery roads and I use one for racing. Better traction all around.
Old Apr 1, 2007 | 12:38 PM
HomerWinzlow's Avatar
HomerWinzlow
Open diff has one other advantage..... far less expensive to purchase, maintain and repair. I see an AWFUL lot of them (limited slip) being repaired in our shop.
Old Apr 1, 2007 | 01:51 PM
96f150's Avatar
96f150
It is what is says "Limited-slip". It means one wheel has to start to spin in order for the other one to start working. Positrac is a GM term. If your clutch packs are too "tight" in the rear end, you will feel it going around a corner.
Old Apr 1, 2007 | 02:11 PM
dynamis5's Avatar
dynamis5
When you say "feel it going around a corner" what exactly do you mean? One of those 'you'll know it when it happens' dealio?
Old Apr 1, 2007 | 02:41 PM
genocidejunkie's Avatar
genocidejunkie
its usually referred to as a chattering sensation
Old Apr 1, 2007 | 03:00 PM
dynamis5's Avatar
dynamis5
Like I said, I have a 04 Lariat 3.73.. Does that automatically come with Limited slip?
I went underneath my truck a minute ago, and tried to find the tag with the "L" I heard about.. I couldn't find it.
Apparently I am not allowed to post pics, so I will try to add it to my Gallery.
Thanks guys for the help so far
Old Apr 1, 2007 | 03:25 PM
phil6608's Avatar
phil6608
Iv been running 4.10s with a L/S diff for over 2 years and never felt a chattering sensation.
Old Apr 1, 2007 | 07:27 PM
Dustin1690's Avatar
Dustin1690
No its an option check on your sticker on the door jamb where it says axle code if its H9 or H6 or something a lettter an number always limited slip if it just anumber like 19 for example or any number it says on your axle code its an open diff non limited slip this applies to these trucks unless someone has changed that out
Old Apr 1, 2007 | 07:50 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the clutch paks are too loose for you to feel the chattering. basically it will feel like a "jumping" sensation and you might hear the tires chirping
the LS is only really usefull for when offroad or during towing. ever tried to tow a heavy trailer in the dirt and not be able to move because of one tire fire?
it does make it a blast to drive when wet though. slip and slides are my favorite time
