Rumble in the rear diffferential
Old Mar 30, 2007 | 09:13 PM
RA81222's Avatar
RA81222
Had this problem for some time.Only does it when backing up and turning wheel an/or pulling out and turning wheel.I was told this was probably the limited slip clutches slipping and grabbing.I had changed the fluid and friction modifier a acouple of months ago and it helped alittle.It seems it may be getting alittle worse now.Would adding more friction modifier help?Or should I just bite the bullet and find a good rear end shop or dealer?
Old Mar 31, 2007 | 07:54 AM
steve(ill)'s Avatar
steve(ill)
Ford said 4 ounces, that is marginal. Aoto Zone sells a 7 oz tube, that is about right. It did help mine.
Old Mar 31, 2007 | 08:23 AM
RA81222's Avatar
RA81222
I think the tube I bought at Advance Auto was 7 ounces.Not sure if adding more would hurt or not.
Old Mar 31, 2007 | 08:30 AM
steve(ill)'s Avatar
steve(ill)
when you turn a corner the two axle shafts are going different speeds and the "spip" between them is the LS clutch. normal response would be if it vibrates or shakes when you turn the wheel, but not in a straight line--- add more friction modifier. if that dont help, then the cluth has a problem.
KenRebF-250
Jul 9, 2013 12:44 PM
96ozarker
Feb 22, 2010 03:12 PM
rhino_160
May 12, 2008 12:29 AM
96f150
1997 - 2003 F150
34
Jan 11, 2008 02:21 PM
mia
Apr 10, 2007 08:52 AM
