Sponsored by: Real Truck
help wont start!
Old Mar 30, 2007 | 07:24 PM
green250's Avatar
green250
help wont start!
I have a 2000 f250 superduty 4x4 with the 5.4 .The truck started this morning and after i shut it off i went to restart it and the starter just clicks!It has power to the starter but one of the relays under the dash clicks when i try to start it.I swapped relays and it does the same thing.Any ideas on this guys?
thanks
p.s.
i replaced the starter and seloniod but it still does the same thing as well as the clicking relay.
Old Mar 30, 2007 | 08:55 PM
high ho silver's Avatar
high ho silver
check the voltage of the battery and make sure both cables are clean at the connectors. It sounds like it is not getting full power to the starter.
Old Mar 30, 2007 | 10:45 PM
emptyd's Avatar
emptyd
Same thing happened to me in a chev@#$@!#$. Turned out to be the batt. connections. Truck had plenty of juice, electric windows worked fine - if they run slow you may have a low amp situation.
Thought I had a bad starter. When the tow guy came out he said "pop the hood" and he did a quick tighting up - and she fired right up.
That'll be the first thing I check from now on. Man, did I feel foolish.
Old Mar 31, 2007 | 11:58 AM
green250's Avatar
green250
update
well i puled the starter back out and shimmed it and presto!She fired right up!.Thanks for the replies guys!
