Busted drive shaft! help!
Old Mar 30, 2007 | 05:08 PM
Agemenon's Avatar
Agemenon
Cool Busted drive shaft! help!
Ok odd enough that this is, I was driving down the highway and I heard this banging and the truck started shaking like a mad man. So I pulled over and checked it all out, i thought it was a flat tire, but turns out the rubber piece that holds the drive shaft together was burnt to a crisp. Without that rubber fitting, the drive shaft was flopping around.
Apparently the bearing seized and it fried the rubber fitting that holds it together? I've never ever had something like this happen before. Is this pretty easy to fix, or do I have to rip apart the whole driveshaft to install a new bearing and rubber fitting?
Any help would be great guys!
Old Mar 30, 2007 | 06:03 PM
bluthunder's Avatar
bluthunder
you most likely will have to take the driveshaft in and have a new bearing pressed on
Old Mar 30, 2007 | 06:44 PM
Agemenon's Avatar
Agemenon
is this expensive work?
Old Mar 30, 2007 | 07:38 PM
datamover's Avatar
datamover
I don't think that will be too much. I have only had a drive shaft shortened. My GUESS would be under $200. I could be way off. Let us know how much it costs. I was thinking of having that done just as PrevMaint. How many miles did you have on the truck when it happened?
Good Luck!
Bob
Old Mar 30, 2007 | 08:12 PM
soupy264's Avatar
soupy264
It's called a hanger bearing, the whole unit is available at a local parts store.1) remove rear drive shaft,from Differential end. 2) slide coupling apart, then remove front shaft from trans. 3) the old bearing remains are pressed off or hammered off.4)
press on new bearing assy. 5)remove the hanger bearing hardware from cross member 6) reassemble in reverse order. or have it done, depending on your mechanical ability
Good luck Phil
Old Mar 30, 2007 | 08:42 PM
Agemenon's Avatar
Agemenon
thanks soupy, that'l save me some trouble. And to answer your question datamover, its got about 90,000 miles on it.
Old Mar 30, 2007 | 08:53 PM
Agemenon's Avatar
Agemenon
hey datamover, how do you take apart the rear drive shaft from the diff?
Old Mar 30, 2007 | 08:55 PM
bluthunder's Avatar
bluthunder
two years ago i had mine done for 75.00
Old Mar 30, 2007 | 08:56 PM
Agemenon's Avatar
Agemenon
hmm that doesnt even sound too bad actually.
Old Mar 30, 2007 | 09:09 PM
datamover's Avatar
datamover
I unhooked the shaft at the universal joint for the diff and the trans. There are bolts on the Universal joint itself. You will see them if you look close. I think you have to be carefull not to let the round caps fall out of the center of the universal. I then put both shaft pieces (still connected) into my Honda Civic and brought it to the shaft shop.
Bob
Old Mar 30, 2007 | 09:18 PM
Agemenon's Avatar
Agemenon
well there's 3 pieces that make up the drive shaft, the universal joint is joined by the 2nd and 3rd piece?
Old Mar 30, 2007 | 09:25 PM
Agemenon's Avatar
Agemenon
I also had this howling noise, and it's pretty loud, could that have been the drive shaft?
Old Mar 30, 2007 | 10:26 PM
PLC7.3's Avatar
PLC7.3
Agemenon........ First thing you do is mark all the parts for alignment before removal.....and I mean all. I would get all the universals replaced and the center bearing.... find a good machine shop....... get the HDuty universals with grease fittings. They will press the old bearing off and the new one on...... I took mine in and had all that done...... I think the total was around $150 cdn....... in Mjaw Sask.
Old Mar 30, 2007 | 10:34 PM
vintage super duty's Avatar
vintage super duty
the howl was probobly the center bearing sizing up its not realy that hard to do your self just do like soup264 said i use a cast iron pipe that is the same size as the bearing race and just tap it on with a hammer wokes graet just did mine 15,000 km. ago
Old Mar 30, 2007 | 11:00 PM
Agemenon's Avatar
Agemenon
what do you mean by mark all the parts for alignment? I should just get all universal joints, and keep the shafts themselves or what? I don't get it.
