Sponsored by: Real Truck
Change diff. gears?
Old Mar 30, 2007 | 03:33 PM
tommyl's Avatar
tommyl
Change diff. gears?
Am thinking of changing diff. gears from 4.11 to 3.73...Question, would this throw off the computer. Have 2000 PSD F350.
Old Mar 30, 2007 | 04:30 PM
emptyd's Avatar
emptyd
Question
I believe that "re-programmers" allow you to enter new data for the drive train components so that speed calc's are accurate.
Dealer can probably do it for you too, but they may charge more $$$ than you'd like - and it may force you into a newer "flash" version that brings along undesired characteristics.
When you're done, do you want to sell your 4.11s? I have 3.73s but it's hard to do a "trade" without one of us not having a vehicle for a while. Anyhow, I might be interested in buying your 4.11s if they're in good shape and are a fit for my truck.
I don't have a clue about what I'm asking here - compatibility wise. I have an '01 X V-10 w/ 3.73 10.5" limited slip. Match?
Old Mar 30, 2007 | 04:35 PM
biz4two's Avatar
biz4two
Arrow
NO. The PCM will calculate the speed fine. No other modification is needed. The only time the speed is effected...is with larger or smaller tires (diameter).
edited
biz
tommyl's Avatar
tommyl
When we get farther along, we'll get back to you.
Old Mar 30, 2007 | 04:43 PM
emptyd's Avatar
emptyd
OBTW: You want to go from 4.10 to 3.73? With a PSD? Those gears are obviously not OEM. The PSD only came with 3.73s...
Obviously biz know what he's talking about a lot more than I do.
Biz, is the sensor in the rear diff used in this process some how? How can the PCM tell what the ratio is?
Old Mar 30, 2007 | 04:48 PM
Beerstalker's Avatar
Beerstalker
Actually I know you can get the 4.10 with the PS but only if you get a dually, at least in the 07 that is how it is.
Old Mar 30, 2007 | 05:09 PM
biz4two's Avatar
biz4two
Arrow
Good catch Beerstalker! I didn't notice he has a F350...and must be a DRW.
biz
Old Mar 30, 2007 | 07:12 PM
tommyl's Avatar
tommyl
Yes,this truck is a F350 DRW
Old Mar 31, 2007 | 12:53 AM
rikosintie's Avatar
rikosintie
"Biz, is the sensor in the rear diff used in this process some how? How can the PCM tell what the ratio is?"
There is a "Tone Ring" on the axle that the computer monitors. Gearing has no effect, only tire diameter.
Michael
Old Mar 31, 2007 | 09:18 PM
biz4two's Avatar
biz4two
Arrow
Michael
Thanks rikosintie! I couldn't have said it better myself...
biz
Old Mar 31, 2007 | 10:32 PM
zhilton's Avatar
zhilton
At a former employer, we had a '04 F350 chassis cab that had 4.30 in the pumpkin. Thought it was rather low gear, but then it wasn't my money buying the truck nor the fuel. I see the truck around town from time to time...so it would appear to be still ticking; though how it's been treated is most likely not in the best of methods.
Old Apr 1, 2007 | 03:55 AM
tommyl's Avatar
tommyl
[QUOTE=emptyd]I believe that "re-programmers" allow you to enter new data for the drive train components so that speed calc's are accurate.
I don't have a clue about what I'm asking here - compatibility wise. I have an '01 X V-10 w/ 3.73 10.5" limited slip. Match?[/
Old Apr 1, 2007 | 03:56 AM
tommyl's Avatar
tommyl
Old Apr 1, 2007 | 03:57 AM
tommyl's Avatar
tommyl
[QUOTE=emptyd]I
I
Old Apr 1, 2007 | 03:58 AM
tommyl's Avatar
tommyl
Emptyd, why would you want to put 4.11 geas in this truck?
