I recently bought a 2007 F250 Short bed crew cab. When driving on the highway above 60mph there is a sway or fish tail type feeling when sudden movements to the steering wheel are made. Basically if I make a quick turn to change lanes or if I'm going around a corner and have to make a quick correction in steering the rear end seems to sway out. I drove the same basic truck at a different dealer before I bought this truck and it did not do it. Some people have said it could be the tires and that different dealers put different tires on the trucks. I have Pirelli Scorpion tires with the pressure set per recommendations but I don't know what tires the other truck I drove had. I took it to the dealer yesterday and they didn't think it was the tires but thought it was the steering box and replaced it. It didn't fix anything.
<O
What is even worse then the sway when driving it by its self, is when I hook up my 32' tow trailer I drive down the road with the rear end constantly swaying back and forth making it hard to keep it on the road. You know how sometimes pulling a trailer and a Big Rig truck passes you and it pulls you into it, well, that happens even when a motorcycle passes me. The trailer is balanced correctly for tongue weight, I use a friction sway control system, and a weight distribution system. The trailer is only ~8,500 lbs which is way below the limits of the truck.
Mine does the same thing at 60+ MPH. I also have the Scorpion tires up to recommended pressure. I truly believe it is just the nature of the tires (tread design), size of the tires, and YES, big heavy truck.
tweimer -- Do you have the sway-bar out back? It comes with a few packages...like the Camper Package, etc.
TIP: While emtpy...I recommend NOT having the tires at FULL specs according to the VIN sticker on the door pillar. There is absolutely NO reason for it while empty.
I just rotated my tires yesterday and now I have the sway as well. It was fine before I rotated them ,but I noticed it within a mile of my house. My rear tires were pretty worn and the fronts are still ok, but were starting to feather and I want to get a few more months out of them. I am going to check the pressures in a little while, but I'm thinking that it might be the warn tires that are on the front wondering. If when I check the psi it does not go away, I will rotate them again to make sure that is it.
