Coolant Temperature Sensor question
on
1 Post
There are two coolant (engine) temp sensors. One operates the gauge in the dash, and the other sends a signal to the ECU/ECM. The one for the gauge has a single wire going to it, and the one for the computer has 2 (or 3?) wires going to it. The gauge one is on the driver's side of the water outlet (where the upper radiator hose goes to the engine), the computer one is on the passenger's side, or closer to it than the other, if that makes sense?
