Aerostar Ford Aerostar
Fuse Box Question
Old Mar 29, 2007 | 04:46 PM
double b from wv's Avatar
double b from wv
Fuse Box Question
hey guys. my friend got this aerostar van...94 model. but we went to check for some blown fuses (tail lights quit working), but could not tell which fuse goes to what. there is no owners manual in the van. and the fuse box cover only shows the number of the slot each fuse is in. so with out the manual, cannot tell what fuses go to what.
so can anyone tell me what goes were? like #1 is for X, ect. i looked for a sticky or faq about this, but didnt see one. so if anyone could point me to one, that would work too.
thanks a lot.
Old Mar 29, 2007 | 08:25 PM
Aeroman59's Avatar
Aeroman59
Hi, fuse #4 does exterior lamps also KAM, warning chime, ABS warning lamp, underhood lamp. It's a light blue fuse 15Amps.
I can send you the glove box manual if you'd like. Dont know if I can post a link to it here, but I can e-mail a compressed version .
Old Mar 29, 2007 | 09:26 PM
double b from wv
thank you. please send me the manual if you would.
btbarnett1980@yahoo.com
Old Mar 29, 2007 | 11:08 PM
copper_90680's Avatar
copper_90680
Hi Double B
Welcome to our FTE forum
Old Mar 30, 2007 | 12:03 AM
asavage's Avatar
asavage
FTE Community Team
If it has the tow package, there is an add'l fuse panel hidden in the side interiour, on the left side of the second row seat, you have to remove (two?) screws to access it. Pic below is from a '91, later years assumed to be similar, 1989 is definitely not like this at all (tow relay panel is behind the jack on the '89 shorty, and has only one fuse but more relays than the later ones).
(click on image for larger)
Old Mar 30, 2007 | 05:04 AM
Aeroman59's Avatar
Aeroman59
Manual Posted
Check your mail..... you need an unzipping program to open it. If you got kids they will sort it for you.
ATB Aeroman
Old Mar 30, 2007 | 12:28 PM
double b from wv
it has a u-haul hitch on the back. would that be considered the tow package?? i mean, i know it can be used to tow, but being a u-haul hitch, its probably aftermarket...wouldnt you think? thanks tho...ill have to check for the second fuse box when he brings the van back over.
Old Mar 30, 2007 | 12:30 PM
double b from wv
ATB Aeroman
thanks again. i have winzip and newztoolz (for .rar's). one of those two outta get it unzipped.
