Sponsored by: Kumho
traction bars?
Old Mar 29, 2007 | 12:44 PM
81fordf-250's Avatar
81fordf-250
traction bars?
I have an 81 ford truck and I have a bad problem with wheel hop and axle tramp. I was wondering if there was anything out there that i could install on it quick and easy to lessen the hop. The truck has factory rear suspension and springs. I know heavier spring help but I don't want to hurt the ride much more. standered traction bars limit the amount of axle travel also I know so is there anything I can do that wouldn't require to much modifications?
Old Mar 29, 2007 | 01:46 PM
hav24wheel's Avatar
hav24wheel
you could make a traction bar that bolts solid to the axle and has a shakle at the end that mounts to the frame. it lets the axle move in its normal arc. but keeps it from twisting.
Old Mar 31, 2007 | 01:31 PM
Farmboy Fabrications's Avatar
add a leafs do a pretty good job.
Old Mar 31, 2007 | 06:07 PM
WinterRoad's Avatar
WinterRoad
Check out www.timbren.com
Old Apr 1, 2007 | 04:38 PM
81fordf-250
ok
One time i saw a truck with some sort of bracket on top of the leaf springs that allowed a shock obsorber to bolt to it one one end and to the frame on the other. would this set up work very well or would it only dampn the jerk a little bit?
Old Apr 1, 2007 | 05:09 PM
it would do practically nothing
Old Apr 1, 2007 | 06:38 PM
81fordf-250
the shock is horizontile and not verticle. It is basicly the same set up as what hav24wheel said only it uses a shock absorber instead of a metal bar. It had a ford motorsports sticker on the absorber so I was wondering if it was some kinda kit ford offered.
Old Apr 1, 2007 | 06:51 PM
i know what you are talking about...but a shock trying to prevent axle wrap is overmatched
Old Apr 12, 2007 | 08:56 PM
90taz's Avatar
90taz
back in the day i had a 77 f-150 with a built motor, i used the traction bars that hav24wheel mentioned. i actually bought them i did'nt make them. they are adjustable at the frame end. they worked great and you could'nt even see them.
Old Apr 13, 2007 | 04:57 AM
79superduty's Avatar
79superduty
the rear springs are probally worn. like farmboy said maybe some new leafs or a new pack it would defenitly stop it.i just installed a 12" lift in a 78 s/c and with no shocks he was burning out withh 33s all day and i didn't see any wrap
Sous
22
May 11, 2015 09:35 AM
OldBlack4x4
Apr 28, 2015 05:18 PM
jav409
Jan 14, 2005 01:19 PM
Cool1996
Dec 13, 2004 12:55 AM
Knucklebuster
May 19, 2003 05:54 PM
