1978 - 1996 Big Bronco
Shifting Confusion... Need part?
Old Mar 22, 2002 | 06:57 PM
Bob_VT's Avatar
Bob_VT
Old Mar 23, 2002 | 10:27 PM
presstone's Avatar
presstone
Upon removing the steering column in my 1988 Bronco (see "'88 Bronco Won't Start!!") I broke the Shift Indicator (white plastic shaft that surrounds coper wire to indicate if I am in Park, Reverse, Drive, etc.) Is there any place where I can find this and replace it? Thanks to anyone who can help!
Old Mar 24, 2002 | 08:29 AM
SBV1's Avatar
SBV1
I would go to Ford or a wrecking yard.
Old Mar 24, 2002 | 10:19 AM
Bob_VT's Avatar
Bob_VT
I am not quite sure exactly what part you are speaking of but.... I have replaced the small cable that moves the indicator. I used a plastic coated steel fishing leader which works fine. I have also replaced the small indicator itself that was broken using a small piece of thin white plexiglass and plastic welder (Epoxy available at walmart). Either way they are just those annoying things we like to have work right.
Bob
