How many HP and Torque in a 300 4.9L engine?
03-31-2004, 07:31 PM
on
How many HP and Torque in a I6 300 4.9L EFI 1994 engine?
03-31-2004, 08:36 PM
03-31-2004, 09:11 PM
on
Hp: Except w/2.73 rear axle or w/3.08 axle: 150 @ 3400.
With 2.73 rear axle or 3.08 axle: 145 @ 3400.
Torque: Except 2.73 rear axle or 3.08 axle: 260 @ 2000.
With 2.73 rear axle or 3.08 axle: 265 @ 2000
i always tell ppl the rpm cus everyones always like dammmm lol
03-31-2004, 10:31 PM
Are those numbers at the flywheel or rear wheels?
04-01-2004, 05:25 PM
on
Quote:
should be flywheel. why is the 2.73 rear end have different numbers. the engine output should be the same.
04-01-2004, 10:28 PM
on
04-01-2004, 10:44 PM
If it's from the flywheel, 2.73s wouldn't make a difference. I'm confussed about the 2.73 though, where did you get that from?
04-02-2004, 03:18 PM
on
alldata, i woudnt know why the would be a diffrence with the 2.73
04-02-2004, 03:30 PM
Ford used a different Cam for specific applications, like the 2.73 & 3.08 gears.
The cam is finessed to operate better for the higher gear ratios.
Published HP and TQ figures are just that, Figures.
Even the computer will be calibrated differently.
6inarowmakeitgo
32
05-05-2022 09:56 PM
FordF350Superduty
73
05-17-2017 10:52 PM
Thedonk
Computer Chips & Tuners
09-16-2015 09:47 PM
Hillcapper
01-10-2008 03:07 PM
hpdiniz
07-18-2000 09:46 PM
