Sponsored by: Auxito
box under left front fender
Old Mar 29, 2007 | 12:04 AM
Schatzzy's Avatar
Schatzzy
Question box under left front fender
what is the box called under the left front fender it has vacum lines and was wondering what it is for thank you this is on early 97
Old Mar 29, 2007 | 06:03 AM
torkum's Avatar
torkum
What engine do you have? 4.2/4.6/5.4
Old Mar 29, 2007 | 06:31 AM
LxMan1's Avatar
LxMan1
It's a vacuum canister that holds vacuum so that under acceleration, you still have enough vacuum to keep the vents on you climate control from defaulting to defrost. Are you talking about the passenger side?
Old Mar 29, 2007 | 10:15 AM
Schatzzy's Avatar
Schatzzy
Yes I am talking about the passenger side. it is the 4.6 and milage is very high
this box is mounted inbetween the out and iner fender too
Old Mar 29, 2007 | 03:21 PM
Schatzzy's Avatar
Schatzzy
got the piece thanks but i would love to be sure what it does for sure and sorry about the mistake about the sides
Old Mar 29, 2007 | 05:02 PM
ncranchero's Avatar
ncranchero
I just replaced a damaged fender and found the reservoir broken in half. Should run much better now......
Old Mar 29, 2007 | 11:34 PM
Schatzzy's Avatar
Schatzzy
exactly what i replace but is it for heater controls or some thing else
Old Mar 29, 2007 | 11:36 PM
Schatzzy's Avatar
Schatzzy
another question i have is why do ford with fuel injection not want to start when the sit for a weekor so i found u have to touch the throtle to get them to start
Old Mar 30, 2007 | 04:47 PM
projectSHO89's Avatar
projectSHO89
1. That is a vacuum reservoir. It is there to keep your vacuum-operated accessories (ie, HVAC controls) from being affected by varying manifold vacuum during different throttle operating conditions.
2. Your IAC valve is probably sticking closed. Cleaning itusually helps in the short term, replacement is usually needed to properly correct.
Steve
Old Mar 30, 2007 | 08:16 PM
F-250LD 4x4's Avatar
F-250LD 4x4
does the 97 5.4 have that same canister? i know i have a small canister about 5in X 5in thats mounted on the battery bracket between the fender. Does the 5.4 also have that huge one between the inner and outer fenders?
Old Apr 1, 2007 | 06:22 PM
apowder97's Avatar
apowder97
Don't know if the 5.4 has the canister in the fender but the 4.6 does have the same canister behind the battery.
Old Mar 10, 2019 | 02:14 PM
Chad Provo's Avatar
Chad Provo
where did you order this from I cant find anything I think it is discontinued if you could help that would be awesome
Old Mar 10, 2019 | 05:33 PM
Sam I Am's Avatar
Sam I Am
The vacuum reservoir is discontinued from Ford.
Since this thread is now 12 years old, they may have still been available new at the time of the previous post.
Unless you luck out and find a dealership that has one still in stock, your best bet is a salvage yard or ebay.
Baby Boomer
WTB - Parts & other
Jun 16, 2017 05:05 AM
DSparksF250
Apr 30, 2017 02:22 PM
fletch
18
Dec 1, 2016 09:44 PM
willjpw
Apr 25, 2016 09:30 PM
Diesel32
Apr 6, 2011 10:52 PM
