Rain Gutter Trim removal
Old Mar 28, 2007 | 10:38 PM
rnelson664's Avatar
rnelson664
My '55 has stainless trim on the cab gutters. It's really on there and I'd like to get it off without destroying it. Any suggestions?
Ray
Old Mar 29, 2007 | 01:15 AM
Fomoko1's Avatar
Fomoko1
Hard to describe the old style can opener used but here goes...
The type I use has a pointed end for puncturing a hole in the can, the other end is rounded for removing bottle caps and is curved at the ends being about 5-6'' long.
Using the rounded end (possibly wraping black electrical tape on it) gently grasp under the back/inner edge of the trim and lift upward to remove the trim. Go slowly in small steps, don`t rush, the trim will get bent or twisted.
Anyone who has done this can jump in and maybe explain it abit better.
Old Mar 29, 2007 | 03:24 PM
rnelson664's Avatar
rnelson664
Thanks Fomoko1, it worked. I used a bottle opener in combination with vice grips that I taped up. It didn't come off perfect but I think I can reuse it after a little reshaping. Thanks
Ray
Old Mar 29, 2007 | 06:28 PM
rhopper's Avatar
rhopper
Fomoko, what you're describing is commonly known as a "church key".
Old Mar 29, 2007 | 06:43 PM
Fomoko1's Avatar
Fomoko1
I`ve seen afew different style of bottle openers, is there one type that`s called a church key or all they all called that?
The one I`m thinking of works pretty slick for removing trim without bending or marking it.
Old Apr 2, 2007 | 08:59 AM
scottjo's Avatar
scottjo
Wow, and I thought that my dad was the only one with that EXACT set-up with the tape and everything! I thought that he was crazy when he handed that to me and said "use this" when I asked him how to remove the stainless.
Old Apr 2, 2007 | 10:53 AM
rnelson664's Avatar
rnelson664
Your dad's a wise man!!!!!!!
BigSkyGuy72
Mar 25, 2013 08:28 PM
mrduke41
1978 - 1996 Big Bronco
Jan 11, 2013 09:37 PM
bigwin56f100
Jan 25, 2011 03:54 PM
medicpg
Oct 25, 2007 04:34 AM
