1978 - 1996 Big Bronco
302 Ho Timing
Old Mar 25, 2002 | 07:05 PM
bignate66's Avatar
bignate66
302 Ho Timing
I own a 1987 Ford Bronco Eddie Bauer fullsize automatic 4x4. It originally had a 351 HO for an engine, but I switched over to a 302 HO. I got this engine as a rebuild & I think it's an 87/88'. I know the firing order for it is 13726548. I don't know what degree to set the timing too though or whether or not it should be BTDC or ATDC? Also what do I line up the marks on the crank too when I set it? Do I need to buy a 351 HO distributor to make it run correctly? On aonther note....Where might I find the fuel filter? Is it in the tank?
Old Mar 26, 2002 | 05:38 AM
Lightning2Fast's Avatar
Lightning2Fast
302 Ho Timing
