high revs
Old Mar 28, 2007 | 07:17 PM
tunruh's Avatar
tunruh
high revs
I have a '93 and '95. w/351/auto. both are 'idling' at 1800-2200 rpm. I bought the '95 that way, but the '93 started after sitting for a couple months. They run fine, but really slam into drive when I start up in the morning, and braking is tougher.
I've actually put rubber caps over the throttle bodies and the things still run. If I unplug the control on the throttle body, they drop to 700 rpm, but drive like crap.
I'm assuming vacuum leaks, but can't find a thing. Vacuum lines all look good.
Do these have a problem with head gaskets?
Old Mar 28, 2007 | 07:21 PM
tweaked250r's Avatar
tweaked250r
Get any codes?
I Heard the throttle body gaskets on these like to leak. Also I would probably clean the IAC Valve (idle air control) and go from there.
Old Mar 28, 2007 | 07:29 PM
tunruh's Avatar
tunruh
is the IAC the unit on the side of the throttle body? if so, that's the control I referred to. If not, where is it. Oh yeah...I'm not getting any codes to read.
Old Mar 28, 2007 | 07:31 PM
rbloodhound's Avatar
rbloodhound
Clean the idle controll valve. Take it off and wash it out with carburator cleaner
Old Mar 28, 2007 | 07:48 PM
Phillip Guidry's Avatar
Phillip Guidry
Clean the throttle plates and bores as well......solvent and toothbrush works fine.....when you restart the motor...it usually acts funny for a couple of blips of the throttle. If that don't cure it...you have a engine coolant temp sensor out of parameter...not broken..just not right.
Phillip
Old Mar 28, 2007 | 07:58 PM
andym's Avatar
andym
A bad ECT will show up in a code scan, and won't cause that kind of behavior anyway.
You have a vacuum leak somewhere. The 351 likes to leak around the intake gasket. Sometimes it will actually suck the gasket in. If you unplug the IAC and the truck doesn't die, then something is feeding the engine air. Without the IAC, the engine doesn't have enough air to run.
I would take the TB off, clean it, check the TPS while you're at it, and clean the IAC. Then see where you're at. If it's still too high, I would check for leaks with an unlit propane torch.
buckfever007
19
Sep 26, 2024 06:57 AM
tobyw
Modular V10 (6.8l)
Dec 2, 2013 08:54 AM
epippin
Aug 28, 2011 10:33 AM
radramrod2
Jul 5, 2009 05:31 PM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
