Engine Stalling without warning
Old Mar 28, 2007 | 08:54 AM
uv199's Avatar
uv199
Hi,
I have a 1992 F-150 with the 302 V8 (EEC-IV), approx 160,000 miles. Recently the engine has been stalling. It seems to happen after it has had a chance to warm up and I have driven it for 10-15 minutes. It will idle nice and smooth and runs well but will stall out, or stutter if I am traveling on local roads and may or may not catch itself, but will stall a few minutes later anyway. I can usually start it back up if it has been off for a minute or two but once the stalling begins it happens more frequently until the next time it has sat long enough. The last time it stalled it took 10 minutes until I could start it.
I checked the continuous error codes and get 18, 41, 31, 32, 33.
18 in the reference show "Spout Circuit" and "Spark Angle Word Failure"
31, 32, 33 seem to be EGR EVP Related
41 is Oxygen sensor.
My question is: Can the EGR-EVP and Oxygen sensor issues cause stalling?
After reading some threads I suspect now that it is Spark related. Possible Ignition Module (TFI Module) which seems more likley since it runs so smooth before it stalls out.
The ignition module must be remotely mounted because it is not attached to the distributer as some threads have indicated. I believe the ignition module on this truck is a grey box with heatsink fins on it that is mounted on the inside fender on the driver side.
Does that type of ignition module have the same failure?
I need some advise from someone with more experience.
Thanks,
Paul
<!-- / message -->
revdave
Jun 7, 2013 03:54 PM
Gordon Freeman
Jun 30, 2011 05:57 AM
chuck460
Oct 24, 2008 07:40 AM
warlord raven
Dec 26, 2003 05:32 PM
fcarruth
1978 - 1996 Big Bronco
Apr 22, 2003 10:06 PM
