3-inch exhaust
Old Mar 27, 2007 | 10:37 PM
Mike O.'s Avatar
Mike O.
Question 3-inch exhaust
Has anyone ran 3 inch exhaust back from their headers?
What did you think of it if so?
Would you do it again?
Did it still elave you with enough back pressure?
Mike O.
Old Mar 27, 2007 | 10:49 PM
slinger34's Avatar
slinger34
I would say that if your engine isnt pushing about 500hp then a 3in is going to hurt you. A smaller pipe will give the exhaust gases more velocity and create the scavenging affect to actually suck the gases out of the cylinder, without being restrictive. For the size I would stick with nothing bigger then 2 1/2 in pipe. I run 2 1/2 on my stock 390 and it performs pretty well.
Old Mar 27, 2007 | 11:36 PM
Mike O.'s Avatar
Mike O.
Yea maybe I being a little greedy. I think I will stick with 2 1/2". Besides I am still in the planning stages. I need to finish my other project first.
Mike O.
53fatfndr's Avatar
53fatfndr
What engine and what mods?
Old Mar 27, 2007 | 11:55 PM
Mike O.'s Avatar
Mike O.
390 engine slightly warm, nothing to fancey. I guess I just would liek the deep rumble. As it is now there are a couple of kids in the begining of my neighbor hood that have car alarms.
I put it in low gear and lightly tap the throttle as I go by and next thing I know there are sirens and lights going of from their cars.
Mike O.
Old Mar 28, 2007 | 09:43 AM
bigperm2's Avatar
bigperm2
I had 3" on my 390, I would definatly go with 3". I even felt that single 3" was too small for the 428. Dynomax has a chart that should help you out. You might ask on the exhaust forum also.
Old Apr 7, 2007 | 03:29 AM
Para045's Avatar
Para045
When I had my previous 78 F100 4x4 4 speed 3.5-1 diffs with a mild 351c in it I went from std manifolds and single 2" system to a dual 2 1/4'' system and extractors and the acceleration at higher revs improved but lost a bit at low revs particularly in 3rd gear as you take off in second third is quite wide.It did allow the engine to rev more and went from ~90kmh in 3rd flat out to ~100kmh flat out and seemed to pull harder up top as well and economy improved markedly. I then went to a 2 1/2'' single system and turbo muffler with the extractors and the top end became even stronger and would rev out to ~110kmh in 3rd and I gained about an extra 20 kmh top speed from stock but did lose some more at the bottom end. This for me was not much of a problem as the truck was used mainly on the road, in fact it was quite nice having the extra go when driving on the street. I would probably not want that big a system on if I were 4WDing a lot as I felt that I lost too much torque down low.
Old Apr 7, 2007 | 10:15 AM
Broken40's Avatar
Broken40
I actually was going to run 3" in as well but it cost an arm and a leg to do it so i decided to stay straight headers....if anyone has any good ideas on how to get it cheaper let me know.... thanks
Old Apr 7, 2007 | 01:17 PM
Mil1ion's Avatar
Mil1ion
FTE has an exhaust forum to learn about Exhaust tuning an engine.
Unless I had a BIG Block Race Car pushing 700 HP I wouldn't ever run that big a pipe.
Old Apr 7, 2007 | 05:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
From my files...
SUGGESTED EXHAUST PIPE SIZES:
Engine HP; SINGLE/DUAL
200-300; 3.0"/2.25"
300-375; 3.5/2.5
375-450; 4.0/3.0
450-550; 4.5/3.5
550-650; 5.0/3.5
650-800; ---/4.0
800-1000; ---/4.5
1000+++: ---/5.0
STRICTLY DAILY DRIVER- GO DOWN ONE SIZE
BIG NITROUS- USE ONE SIZE BIGGER
Old Apr 7, 2007 | 10:46 PM
kilog55's Avatar
kilog55
check the xhaust forum i posted a vid with my 79 with a basically stock 400 with dual 3" and flowmasters i love tyhe sound but would like more grunt on the bottom end
Old Apr 7, 2007 | 10:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
Managing to kill the bottom end on a 400 with an exhaust system is some trick...
Old Apr 7, 2007 | 11:05 PM
kilog55's Avatar
kilog55
yeah tell me about it i didnt do the exhaust it was like it when i bought it. they fabbed the pipes out of a roll bar just cut and welded em to fit so i have 3" duals that are almost a 1/4 inch thick walled some hills i gotta go into 3rd just to pull em after i wind it out on a start.
but soon that will be a thing of the past when i build the motor up
Old Apr 7, 2007 | 11:32 PM
garypettengill's Avatar
garypettengill
I have a 3" on mine. 2 1/2" from each collector into a 3" pipe through a 3" flomaster and out the back. Looks stock, just bigger. Sounds nice too.
Old Apr 8, 2007 | 06:51 AM
2tone73's Avatar
2tone73
I wondered the same for my 73. So I called Flowmaster and one of their techs told me to use stock 2 1/2 in exhaust into 1 flowmaster(40 series). He also said to throw away my radio because I wouldn't be able to hear it. I acquired two sets of flowmasters, one is 2 1/2 in and out and the other being the 3in. Now its a neighborhood alarmclock!
