Reseting anit-theft
Old Mar 27, 2007 | 10:00 PM
DaMole's Avatar
DaMole
Reseting anit-theft
I got a friend with a 1994 F-150 5.8 4x4 that he just got. He is having some trouble with the anti-theft going off (staying on) and has had to unplug it . How do you go about reseting the anti-theft system?
Thanks guys
Old Mar 27, 2007 | 10:04 PM
BrilloDuck11's Avatar
BrilloDuck11
I am the friend he is talking about
Old Mar 27, 2007 | 10:05 PM
quicklook2's Avatar
quicklook2
you omited to say if it comes from ford or is aftermarket.
Old Mar 27, 2007 | 10:11 PM
BrilloDuck11
It is the from the factory anti-theft. I do have the remote door locks also.
Old Mar 28, 2007 | 07:08 AM
NeXtras's Avatar
NeXtras
so you want to shut the alarm off? as in valet mode so you can unlock the doors with the key and the alarm not go off? OR does the alarm sound after you lock it and no one has touched it?
if you want to put it into valet mode just press the red blinking light once. if the alarm goes off when it should not, you may need to replace the motion sensor which i believe is located in the alarm spreaker its self
Old Mar 28, 2007 | 11:39 AM
quicklook2's Avatar
quicklook2
the ford manual says you have either:
-open/short circuit
-switches
do you mean the personal panic button alarm? the owners manual does not say that these vehicles have anti theft alarms from the factory.
Old Mar 28, 2007 | 01:13 PM
NeXtras's Avatar
NeXtras
they do have factory alarm systems. Mine has it as well... the alarm module is located to the right of the brake booster
Old Mar 28, 2007 | 01:31 PM
quicklook2's Avatar
quicklook2
i think it just the wording of the manual.
Old Mar 28, 2007 | 04:05 PM
BrilloDuck11
Ok here is what happens. It is a factory anti-theft. I am not talking about the panic button. The module is to the right of the driver seat about half way between the driver and passenger seat under the dash. It has two connectors plugged into it. Which are both currently unplugged. When i open the door nothing goes off. When I put the key in the ignition and start the truck, or put the ignition to on or acc there is a beeping coming from the module. The beeping does not stop. The only way I have found to stop it is by unplugging the connectors plugged into the module. Please help.
Old Mar 28, 2007 | 05:06 PM
quicklook2's Avatar
quicklook2
that sounds liike the module for door open with keys in the ignition or seatbelt not attached.
one of your door switchs is probably faulty.
Old Mar 28, 2007 | 08:41 PM
BrilloDuck11
Is there an easy way to check and see which one is faulty?
