1978 - 1996 Big Bronco
Ignition system
Old Mar 27, 2007 | 08:32 PM
cfrives3's Avatar
cfrives3
Ignition system
Does anyone know which ignition system came on the 86 EB's? (351W) Better yet, what do I look for to find out for myself?
Old Apr 3, 2007 | 09:02 PM
ReAX's Avatar
ReAX
I'd suspect that you have a carb and duraspark 2. Duraspark 1/2 is distingished by the color of the connector or one of the wires in the harness. The duraspark module is a steel box about 4"x4" bolt on to the drivers side fender usually. If you start at the distributor, two of the three wires should run right to it. the harness from the coil should also go there.
Old Apr 3, 2007 | 09:38 PM
Aciancio's Avatar
Aciancio
Im not sure when ford changed the 351 over to EFI. If yours has a carb you have the duraspark 2 if it has EFI then you have the EEC IV. one other quick way to check is look at your distributor, If it has a Vacuum advance you have the duraspark 2 if there are wires coming from the side of the distributor you have EEC IV
sweetlou1
Mar 3, 2013 03:58 PM
qbert
Sep 10, 2010 11:51 AM
MONAVIERONJON
Oct 20, 2009 09:26 AM
fordflaresides
Dec 12, 2005 05:35 PM
rwmorrisonjr
Bronco II
Aug 26, 2005 08:30 AM
