Headlights
Old Mar 27, 2007 | 01:41 PM
clarkbr's Avatar
clarkbr
Question Headlights
Hello All,
I have a 1998 Explorer Limited.
The headlights come on at night automatically. I like this, but it makes me lazy.
I can't use the lights while boarding Ferry boats - it blinds the crews on the boat and on the dock.
How do I turn them off or switch them to just the running lights?
I can't find anything on this in the manual.
Thanks,
Brian
Old Mar 29, 2007 | 07:55 AM
don96exp's Avatar
don96exp
I believe it the same as the '96 . there is a on/off switch (button) and also a slide button which controls the amount of time the headlights remain on after you turn the car off. These are located on the rear view mirrow.
Old Mar 30, 2007 | 07:23 PM
whooboy's Avatar
whooboy
Same on the '98. There is a slide on the bottom of the rear view mirror. Slide it all the way to the left and you will have manual lights. The slide adjusts the time the lights stay on after you turn off the engine. There is also an indicator light up there that comes on to indicate that the system has turned on the lights.
Old Mar 31, 2007 | 10:28 AM
Larry85355's Avatar
Larry85355
While we're on the subject...I have an 87 that the headlight wont work.
The high beams will come on if you pull on the momentary switch and the parking light will work like they are supposed to.
Does anyone know if there are more that one fuse? If so, which ones are they?
Have there been alot of switch failures on these trucks?
I do not have a shop manual or an owners manual for this truck.
Old Mar 31, 2007 | 01:35 PM
87 XLT's Avatar
87 XLT
No fuses on this one. The fuse link is wired to the headlight switch on the dash which is wired to the dimmer switch, which is wired to the low & high filaments of the headlights.
Only 2 things this could be. Bad dimmer switch, or the low beam filament in each headlight could be burned out..
If the low beams quit working at the same time, replace the dimmer switch.
Old Mar 31, 2007 | 02:03 PM
quicklook2's Avatar
quicklook2
or the headlight switch itself.
Old Apr 1, 2007 | 12:07 AM
kevin74656's Avatar
kevin74656
This should help.
https://www.ford-trucks.com/forums/5...left+headlight
Good luck!
Old Apr 1, 2007 | 12:13 AM
aquanaut20's Avatar
aquanaut20
last time mine acted this way it was the main headlight switch on dash, re/re, fixed problem
MC5C
Nov 7, 2013 01:06 PM
Coupleofords
Jun 12, 2007 02:36 PM
n9lhm
May 14, 2005 02:22 PM
bstack
Car/truck Buying Advice
Oct 13, 2004 05:59 PM
Terrafermi_1
Paint & Bodywork
Apr 24, 2002 09:50 PM
