Sponsored by: Auxito
Can someone help
Old Mar 27, 2007 | 08:59 AM
hienie's Avatar
hienie
Can someone help
I have a 2001 F150 Supercrew 4X4. At the last service the dealership advised me that I was going to need to have the rear yoke replaced but did not indicate it was urgent. I am not having any dripping from that area but I do notice a discoloration on the rear end housing just behind the yoke. I am wondering how soon I will need to get this fixed and if taking a fairly long, 600 miles, trip before will hurt anything.
Thanks,
hienie
Old Mar 27, 2007 | 09:05 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
Did they say why it needed replaced? is it worn or just leaking?
Old Mar 27, 2007 | 09:35 AM
hienie's Avatar
hienie
They didn't say. It was my impression thou that it was leaking and it probably would get worse
Old Mar 27, 2007 | 12:24 PM
86moneypit's Avatar
86moneypit
When discoloration happens on metal it is usually a sign of overheating.
Old Mar 27, 2007 | 02:19 PM
hienie's Avatar
hienie
This dicoloration is dark and looks like it is some form of liquid . There is no dripping however but it is greasy/oily wet to the touch and makes the rag black when wiped off.
Old Mar 27, 2007 | 05:52 PM
steve(ill)'s Avatar
steve(ill)
a small drip can buildlup over time and stain or "wet" the pumpkin box. this is not a immediate problem. as long as you add a cup of new gear lube, maybe once a year, you could run the truck indefinetely. small leak does not mean a failure is emminent.
