egr help
Old Mar 27, 2007 | 07:37 AM
Kenwood's Avatar
Kenwood
egr help
OK I know I stumbled across this before But I cant find it even with the search..
2004 >> I have the fun and excitement of the EGR curse... upon load the truck bucks and blows smoke... I know its the EGR because when I remove and clean it and reinstall the truck runs perfect for about 8 months..then same BS happens again.. Its never THAT dirty But I guess just enough to cause an issue..
ANYWAY.. What is the part number for the NEWER/HEAVIER SPRING updated EGR valve for the 03/04 models?? I remember reading where they have an update PN for one with a heavier spring.. ALSO I am assuming that I can just swap this one in>>as in there is not different programing that factors in with the swap..IE no reflash..
With the 100 deductable Id rather just swap the EGR myself and spend less..
Old Mar 27, 2007 | 08:56 AM
ciscofreak's Avatar
ciscofreak
I'm also curious as to when I should bring my truck in for EGR issues. I want to make sure I get the updated valve instead.
Old Mar 27, 2007 | 09:41 AM
Kenwood's Avatar
Kenwood
Well I dont want to take mine in simply because its hit or miss... Chances are if I bring it in they will say everything is OK.. and send me packin..Untill it gets sooo bad that they will easily have it happen..
I found the TSB.. newer PN is 4c3z-9f-452-a
Old Mar 27, 2007 | 10:03 AM
BowTieHatr's Avatar
BowTieHatr
the egr vavle is more than 100 bucks.
Old Mar 27, 2007 | 10:57 AM
kw5413's Avatar
kw5413
For the non California emissions '04 MY...Some might say.... ....get a new one. Drive it of the lot. Shut down the engine. Unplug the little WART.
Old Mar 27, 2007 | 11:07 AM
BowTieHatr's Avatar
BowTieHatr
very true keith but for the scenerio kenwood is describing is the valve is opening under pressure. unplugging wont fix this.
Old Mar 27, 2007 | 11:24 AM
kw5413's Avatar
kw5413
Well there you go...getting technical again.
Oh yeah...that's what you're supposed to do.
Old Mar 27, 2007 | 11:27 AM
BowTieHatr's Avatar
BowTieHatr
sorry not working today. well im here just not the work so i have some brains to share. lol
Old Mar 27, 2007 | 11:38 AM
Kenwood's Avatar
Kenwood
ONLY if you buy itfrom the dealership..
Old Mar 27, 2007 | 11:49 AM
OZX1's Avatar
OZX1
I'll take you up on that offer, BowTieHatr! an excerpt from my "Trip" post, "...He told me that he read some codes. I'm thinking {how did he do that? I cleared the KAM before I left the house}. Anyway, the truck popped a P0401 (from the EGR unplug of distant past) and a P1328 that is a WHAT?? I have NO idea..."
My question are:
  1. Does killing the KAM clear codes? (my guess is now, NO!)
  2. What the heck is a P1328 code?
Your professional insight is appreciated
Mildly and only a slight
Old Mar 27, 2007 | 01:03 PM
BowTieHatr's Avatar
BowTieHatr
03s and early 04s have a wild strategy for the pcm to create boost. p132b code is where the strategy has not been learned or there is a problem with the strategy learning procedure. several of the sensors could be off, or you clearing kam could do it if the proper steps are not followed for the relearn procedure. my question is why would you reset kam anyways? this effects the strategy that these trucks need.
Old Mar 27, 2007 | 01:14 PM
OZX1's Avatar
OZX1
I neglected to mention the VGT relearn was also completed after the KAM kill. I did it after I took the power elbow off in an attempt (however feeble) to return the trucks strategy to that of a "stock" configuration. It is apparent that I guessed wrong, and/or the static VGT relearn strategy is insufficient to keep the p132b code (thanks for the correction) from throwing...
Redneck1465
Ford Truck Parts for Sale
Jul 12, 2013 05:11 PM
FossenRacing
Sep 30, 2012 01:20 PM
brkncly
6.4L Power Stroke Diesel
Aug 2, 2012 08:25 PM
pickncrew
Mar 15, 2008 07:26 AM
Green_Monster
Jun 30, 2007 04:47 PM
