Bolt Pattern, did it switch?
Old Mar 27, 2007 | 06:03 AM
RangerPilot's Avatar
RangerPilot
I'm well aware that my '94 has the 5 x 4.5 bolt pattern. But I seem to see a lot of late '90s Rangers running around with what appears to be a tighter lug nut pattern. I see it on the B-series, too. Did the bolt pattern for the wheels switch at sometime or another? I'm trying to find out if an aftermarket set of wheels from a '99 Ranger will fit on my '94.
Thanks.
Old Mar 27, 2007 | 08:32 AM
fordboy_52's Avatar
fordboy_52
well if u were closer, id take my wheel and put it on your truck and tell you. sorry
Matt
Old Mar 27, 2007 | 09:52 AM
RangerPilot
Do you have any pictures of your wheels Matt? I think that would pretty well solve it as well, unless someone knows for sure.
Old Mar 27, 2007 | 09:55 AM
fordboy_52's Avatar
fordboy_52
i do not, but here is a link
http://cgi.ebay.com/ebaymotors/EXPLO...98442054QQrdZ1
Matt
Old Mar 27, 2007 | 09:58 AM
RangerPilot
Thank I'll check it when I get home, eBay is blocked here.
Old Mar 27, 2007 | 10:05 AM
fordboy_52's Avatar
fordboy_52
doh... sorry
here is a pic borrowed from there
Matt
Old Mar 27, 2007 | 10:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford went to metric wheels in the mid 1990's. Wheels will not interchange on older models.
Old Mar 27, 2007 | 10:13 AM
fordboy_52's Avatar
fordboy_52
numberdummy. you are a very knowledgeable person. thanks
Matt
Old Mar 27, 2007 | 11:45 AM
rubydist's Avatar
rubydist
Not on Rangers, they didn't. All Ranger wheels are 5 on 4.5" pattern with 12mm offset. I have Cragars on my '03 with 5 on 4.5" pattern. Guys have put Mustang wheels on all years of Rangers.
Old Mar 27, 2007 | 01:31 PM
blueranger99's Avatar
blueranger99
I have a spare set of 15" steel wheels off of a late 80's Ranger for my '99 - they fit perfect...
Old Mar 27, 2007 | 03:24 PM
wtroger's Avatar
wtroger
On my 2003 ranger I use 1986 Ford Crown Victoria wheels to mount my Studded Mud and Snow tires. Mine at least is still the old Ford passenger car wheel pattern. And before somebody hollers There where some middle to late 70's Ford cars the used the Bigger Chevy 5 hole bolt pattern. I know that the old f100 rangers that where full size in the early eights used the small bolt pattern while the F-150's used the old lot larger standard Ford truck pattern.
The Lug bolts went metric either 12 or 13 mm I haven checked those yet.
Old Mar 27, 2007 | 05:17 PM
RangerPilot
Ok so I take it that the '99 rims will fit on the Ranger without any problems whatsoever?
Old Mar 27, 2007 | 05:59 PM
k460's Avatar
k460
Ya, check out my gallery newer rims on my 93
Old Mar 27, 2007 | 06:14 PM
GrayRanger4x4's Avatar
GrayRanger4x4
The 4x4 center hole is bigger on ALL 4x4 Rangers, they will fit the 4x2 bolt pattern, but the 2x4 will NOT fit the front of a 4x4 Ranger.
I know that an 89 4x4 Ranger wheel will fit a 96 4x4 Ranger nicely, at least they do on mine.
Old Mar 27, 2007 | 06:41 PM
rubydist's Avatar
rubydist
On my '03, the lugs are 1/2-20 just like the Fords have been forever. I don't believe these have changed to metric on the newer ones either.
