Compression test
Old Mar 26, 2007 | 04:46 PM
smoulding's Avatar
smoulding
Compression test
Here's a question.
Is there any way you can figure compression ratio using a regular compression tester?
Old Mar 26, 2007 | 05:26 PM
acheda's Avatar
acheda
You cannot accurately determine compression ratio from a tester reading as cam timing, carbon deposit build-up, & other factors determine the reading of the compression tester in addition to the basic compression ratio.
Higher compression ratio engines can have higher readings, but a wild cam could reduce that number quite a bit.
