1978 - 1996 Big Bronco
AC dragging engine down
Old Apr 12, 2002 | 08:33 AM
bn's Avatar
bn
I have an 88 Eddie Bower with around 92K miles. Whenever I turn on my AC (defrost, etc.) my RPMs drop significantly and it sounds like the engine of my truck is really getting worked hard. This happens whether I am driving or just idling in park. Also, there is a small clicking noise coming from the AC motor. Is this typical or should I replace my blower motor??
Thanks for the help
Old Apr 12, 2002 | 09:03 PM
Bob_VT's Avatar
Bob_VT
Check the charge in the system. You might be over or undercharged. If it was converted to the "over the counter" and not done properly your system may be in distress. Check the air conditioning cooling radiator...is it clogged with bugs and road crap?
It is natural for the AC to put a load on the motor.
Bob
Old Apr 15, 2002 | 02:20 PM
bn's Avatar
bn
I appreciate the help. Sorry to show my ignorance, but how do I check the charge? I don't guess I would worry quite as much about the draw that the AC seems to be taking except I am just afraid of the AC motor locking up since it shares a belt with so many other things.
Bobby
Old Apr 15, 2002 | 02:35 PM
Bull's Avatar
Bull
The clicking nose from the AC compressor is the clutch engaging and is normal. While your AC is on, it should click on and off depending on the temp settings.
Old Apr 15, 2002 | 03:40 PM
adelyser's Avatar
adelyser
If you A/C is kicking on, then you at least have a decent charge. If your charge drops below a certain point, the A/C won't even kick in. You could have some binding in the compressor. Is the clutch pack getting hot at all? If so, then you may need oil, or a new compressor soon as it could be binding or a bearing could be going out. There could also be a blocakge in the system making the compressor work more than usual. The A/C in my Bronco never made the engine work really hard, even when we took a trip to Florida. It would kick on, and you wouldn't even notice it. One day, the compressor froze and it hasn't been the same since.
Just FYI, if you need a recharge, or a new compressor or part, now would be the time to change over to R134 if your vehicle hasn't yet. With the price of R12, the change over and recharge is usually about the same price of an R12 recharge.
Old Apr 15, 2002 | 07:17 PM
restorit's Avatar
restorit
Power of 8
Feb 24, 2017 07:42 AM
92will
Oct 5, 2016 06:25 AM
derail1313
Modular V8 (4.6L, 5.4L)
Oct 8, 2015 06:59 PM
riverbedjedd
Jul 19, 2015 09:37 AM
farmF-150
Oct 28, 2003 08:10 AM
