rev limitor on a mallory dizzy
Old Mar 25, 2007 | 09:53 PM
robertbourque's Avatar
robertbourque
one more question it seems like i have a rev limitor but .its a malory dual point distribitor converted to eltronic led sensor .but has no setable rev limitor .is the rev limitor set into to dizzy advance curve or could it be form the droping rezistor im using .it seems to start sputtering at like 6000 rpms and after i hit it the motor is real slugish for a couple seconds like it got flooded .
Old Mar 26, 2007 | 02:57 AM
LxMan1's Avatar
LxMan1
Sounds more like valve float to me. The Unilite is acurate to 8000+ rpm.
Old Mar 26, 2007 | 04:16 AM
HemiEater's Avatar
HemiEater
that cam you have should be all done by 6000 it might pull to 6500 .....your valves spring are more than likely holding it at 6000. Check the cam card for the rpm range....
Old Mar 26, 2007 | 10:32 AM
robertbourque
ok so is it real bad to float the valves .so i guess i will shift under 6000.thanks for the replys
Old Mar 26, 2007 | 04:57 PM
LxMan1's Avatar
LxMan1
Yes, you keep doing that and you can launch a pushrod or worse, drop a valve and ruin the whole engine!!!
