It's time to let my winter beater go.I drove it for 5 winters and this is it.It's a 1988 F150 4x4 Lariat trim,5.0, 5spd ,runs ,drives ok,needs breaks and who knows what else.The tranny is weak as it pops out of rev,it's also very rusty.A/C is dead,c/c and D side window Dead.But there is some good parts on it,take a look here in my gallery https://www.ford-trucks.com/user_gal...&albumid=27418
What do you guys think it's worth?This dude from work offered me $300 bucks.Let me know what you think.
It`s way too rusty to ask $1,000 but $300 does seems abit low depending on how good the motor runs and if it uses lots of oil.
Maybe somewhere in between, say $700-750 as you can always come down till it sells.
Yeah 300 is too low. Like Fom says. 700 to 750 sounds more like it. You said the tranny is popping. But the tranfer case and diffe are worth that much, so is the motor if it is still deecent.
I go a 1000 or best. You should get 700 for it.
i just paid 650 for a 88 ext cab 4x4 xlt lariat. Needing exhaust cracked wndshld.not to rusty. I think the engine alone is worth 250 if it runs. I give ya 500 so thats what id say its worth. Without seeing it. To bad your not closer to regina. I need parts.
Lots of early 80's ford truck parts fit the 88. Rads , and egine parts just trim packages are different. we should have stuff for you down your way Wreck.
what do you need for parts man? i have lots left over
