will it store codes??
Old Mar 25, 2007 | 06:42 PM
jsmallwood_2000's Avatar
jsmallwood_2000
I am being told that my 2003 expy will not have stored codes unless the check engine light is on. It keeps hesitating on acceleration, and I do not have any lights on yet. Will it show something?
Thanks
Old Mar 26, 2007 | 01:16 AM
yardbird's Avatar
yardbird
My '03 will store codes without the check engine light coming on. I keep getting P0305 and P0316. I will clear them and in a few days or weeks they will return.
I just wish I could clear the engine miss as easy as I can clear the codes.
Old Jan 14, 2008 | 08:11 PM
madmoney1196's Avatar
madmoney1196
change the number 5 cyl your codes will stop . just rember to clear codes after new coil and plug
Old Jan 14, 2008 | 10:09 PM
yardbird's Avatar
yardbird
New coil, plug, and injector in #5, still will miss occasionally upon cold start on #5.
Old Jan 15, 2008 | 04:44 AM
ford390gashog's Avatar
ford390gashog
My expy did that too. The main harness going to the firewall had moisture that would build up because the seal failed.
Old Jan 15, 2008 | 11:16 PM
yardbird's Avatar
yardbird
I'll check that harness. I also loose my fuel pressure within a few minutes after I shut it off, so that may contribute to the problem. I have to cycle my switch at least three times to get it to start. I haven't checked to see if it is a bad injector or the fuel pump leaking back.
I don't drive it much anymore. It has been sitting for a month without leaving the yard. I did move it once.
I was using the Expy to pull my car trailer, but I bought a (don't flame me) Dodge 2500 pickup with the V-10 to pull with now. Much, much more power, same gas mileage.
It's a fairly low mileage '94, and being a dealer I got it so cheap I can't bear to wear out my Expy doing the grunt work.
mlj1st
Nov 1, 2016 05:27 PM
steedpower
Oct 6, 2016 08:30 AM
oxt127
Apr 30, 2016 05:51 AM
sudsmcduff
Nov 14, 2015 06:10 PM
429law
Dec 15, 2007 07:41 PM
