Modular V10 (6.8l)
Surging at idle
Old Mar 25, 2007 | 04:20 PM
Sundance Kid's Avatar
Sundance Kid
Unhappy Surging at idle
I have a 99 350 dually. A week ago I got a check engine light and it was running a little weak. When I put my decoder on, it read a lean rt bank. I cleared the code and it did not come back. Now it surges at idle and is more distinctive when it is drive. It feels like I have a big cam it. (no codes) We checked the fuel filter and it was clean. Fuel pressure is good. We unplugged the mass air senser and it smoothed out. So I replaced the senser. Started it up and it ran fine for a while then started to surge again but not as bad. Any Ideas what to check now? Thanks
Old Mar 25, 2007 | 05:30 PM
FortyFords's Avatar
FortyFords
Iac control valve or a plugged orfice to it .
Could have a vacum leak at pcv elbow or intake o-rings
Rich
Old Mar 25, 2007 | 05:47 PM
Sundance Kid
What is the Iac control valve
Old Mar 25, 2007 | 05:52 PM
Fredvon4's Avatar
Fredvon4
Idle Air Control
Is up on pass side top---- right behind the throttle body and Controls the Air during Idle
Gets gummed up and stuck often...can be cleaned and reinstalled, use B-12 chem tool or similar, or just replaced..not very expensive part
Old Mar 25, 2007 | 10:42 PM
biz4two's Avatar
biz4two
Arrow
Take a look in my gallery. I have a step-by-step with pics. Also...have the FORD/Motorcraft part #.
https://www.ford-trucks.com/user_gal...&albumid=22274
biz
Old Mar 26, 2007 | 09:03 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Having already checked the MAF, a lean code would probably be a vacuum leak - check the PCV plumbing (especially the elbow at the throttle body).
Old Mar 26, 2007 | 11:15 AM
FortyFords's Avatar
FortyFords
Must be a ECHO in here!!!!!!!!
Rich
Old Mar 26, 2007 | 11:18 AM
SLE's Avatar
SLE
Kewart is on it, check the 90 degree PVC Elbow and associated plumbing. A guy I work with just got the exact same systems and code on his 5.4L powered expedition, it was a cracked elbow! It cost him a $100 to have someone find it and fix it. If he'd would have said something before he took it in I could saved him $98, lol.
Old Mar 26, 2007 | 11:19 AM
SLE's Avatar
SLE
Sorry forty, I only read the last couple of posts, Credit should be give where credit is due, lol!
Old Mar 26, 2007 | 11:41 AM
Big Orn's Avatar
Big Orn
I agree SLE. Ol Farty never gets the credit he deserves, bygawd!!
Kudos to Farty!!!
Old Mar 26, 2007 | 12:04 PM
krewat's Avatar
krewat
Rich
Echo... echo... cho.. ho... o... o... o... o...
Rich is DA MAN!
I just keep repeating what he, Fred, and lots of others have said here...
Old Mar 27, 2007 | 04:26 AM
FortyFords's Avatar
FortyFords
Old Farty ! okay Big Horn start tootin it!!!!!
Hello ! Hello! anybody listening ?????????
Oh sorry! I thought this was the phone!
Art ,you there ,dang hearing aids
Rich
Old Mar 27, 2007 | 06:32 AM
Big Orn's Avatar
Big Orn
okay Big Horn ...
That's what the girls once called me....long ago when there was no moon and the sun was the size of a grapefruit...
You know I love ya, Rich...
Old Mar 27, 2007 | 08:17 AM
krewat's Avatar
krewat
Is this thing on? (tap tap tap)....
Old Mar 27, 2007 | 08:06 PM
Sundance Kid
This site rocks!!!! After reading everyones advice and a little looking under the hood. I found the culprit to my woes. It appears that you guys are more than a pretty face(ha ha ha). It was the rubber 90 degree elbow going to the pvc. It looked like it's gotten weak from oil deposits and collapsed from the vacuum tearing it at the bottom of the metal nipple. (did I say nipple!!!). If you would just look at it there was nothing physically wrong. I had to pull it off from under all the other crap to get a good look. The trucks running great again thanks to all of you! Just to recap for other folks. The motor was surging at idle and more distictive when it drive with the brake on. We found the MAF senser bad and the split on the rubber elbow. Once again thanks to all.
