I will soon be towing a 10' landscape trailer with a 2000 Explorer Sport 2WD. I don't expect loads to be too heavy, maybe 2500 lbs at the most.
I have two questions:
The rear has single leaf spring pack. I know this is good for almost nothing. I am thinking of installing either air shocks or a coil over shock. Does anyone have experience with either or both?
Also, I see that there is a factory remote trans cooler. Is this one large enough to tow with or should I replace it with a larger aftermarket piece?
If your towed weight estimate is right, multi-leaf springs would probably be overkill. Plus, your Ex will ride rougher when not towing. Try the bags first.
