Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
blasting
Old Mar 24, 2007 | 09:28 PM
77f-250HB's Avatar
77f-250HB
blasting
hey guys.
its almost time for me to get my cab blasted down to bare metal...
im looking for a place in saskatoon, who can you recomend?
and what methed should i use to make sure it doesnt warp the metal?
sand, bead, ect.
i'm looking to get my cab and doors, inside and out done.
what price range am i looking at also?
Thanks in advance!
Marshall
Old Mar 24, 2007 | 09:36 PM
Snowking's Avatar
Snowking
Where I used to work my boss charged 120 a hour for sand blasting, to do doors and cab I could probably do it in 1-1.5 hours depending on wha degree of a blast you're looking for.
Old Mar 24, 2007 | 09:38 PM
77f-250HB's Avatar
77f-250HB
what do you mean by degree?
Old Mar 24, 2007 | 09:49 PM
Snowking's Avatar
Snowking
The harder (sorry can't think of better word) you sandblast the metal, it will turn to more of a white colour.
For a truck restoration it is quite common to do a light blast, but many people do a "white" blast.
A light blast will knock off rust and take off any imperfects in the paint coat that is currently on the truck, it gives the metal a rough surface that primer/paint loves to bond to and will take off a few layers of the old grummy paint.
A white blast will do all that but much better, when a truck is white blasted it is down to the bare metal.
Fomoko1's Avatar
Fomoko1
There was an excellent place in Sutherland for all types of good quality automotive sandblasting but unfortunately they closed down a couple of years ago. They used to charge $150 to do a complete on a 65 Mustang coupe underneath, inside and out.
Last fall I took some Bobcat rims to Bandit Blasting & Painting-71st St & Idylwyld Dr. 934-0008. They did a great job, the cost was $100 for 4 rims which wasn`t bad. I have no idea of the cost for a cab.
Old Mar 24, 2007 | 09:54 PM
77f-250HB's Avatar
77f-250HB
snowking..the white blast sounds like what i'm looking for.
will i have to worry about warpage?
but since you have been in the bisness what can you recomened for me?
as for a place to take it to, and a method?
Old Mar 24, 2007 | 10:08 PM
Snowking's Avatar
Snowking
If you take it to a place they know what to do. I don't have any expierence with who to take it to but every once in a while you see body parts blasted in Bandits lot. That blaster I ran for awhile you would never try to do body panels. I did the grille for my 1957 though.
If you find a machine to do it, just use a couple quick test pieces, see how much pressure is coming out.
Generally though for a body part and a high pressure blaster 100cfm and up hold the nozzle about 12inch. away.
The only pieces to be carful of warping is were it is flat and thin, like bottom half of doors and box sides. anything with a curve, reinforced ain't gonna warp unless you hold the nozzle ridicously close.
Old Mar 24, 2007 | 10:20 PM
77f-250HB's Avatar
77f-250HB
have oyu guys heard aything about Totally Blasted?
Old Mar 24, 2007 | 10:25 PM
Fomoko1's Avatar
Fomoko1
I have never heard of Totally Blasted, are they in Saskatoon?
Old Mar 24, 2007 | 10:27 PM
77f-250HB's Avatar
77f-250HB
indeed
check out mysask.ca
Old Mar 24, 2007 | 11:20 PM
66gpw's Avatar
66gpw
I have not had anything done yet. I contacted Bandits about blasting a box 2 years ago and they were charging 75.00 for a box. When I talked to them they seemed to know what they were doing. They said they use lower preesure and diffirent sands for sheet metal on vehicles to reduce any chance of warpage. I seen them blasting trucks in the yard during the summer months. usually truck frames.
Maybe talk to a powder coat place and they can help send you to a good reputable sand blaster.
Old Mar 24, 2007 | 11:36 PM
77f-250HB's Avatar
77f-250HB
thanks for the tip 66gpw!
Old Mar 25, 2007 | 04:47 PM
77f-250HB's Avatar
77f-250HB
curious if i have to take the glass out of my doors?
front and rear window are already gone...
does it matter if the doors are on or off the truck?
have any of you have had blasting in stoon?
Old Mar 25, 2007 | 04:58 PM
Snowking's Avatar
Snowking
The glass will have to be taken out sand blasts everywhere and would most likely cause dmage to any glass still in.
It would be easier to blast with doors out, I say tak'em out.
Old Mar 25, 2007 | 05:00 PM
77f-250HB's Avatar
77f-250HB
okay.
doors are already off...have been for a couple months lol..
how do i go about take the door glass out?
