i am having the problem of my life. my 85 bronco has bad rotors. it also has manual hubs. i took of the wheel and removed the cap from the hub. i took out the inner portion and the split ring from the axle. i cannot get anything to move. is there another ring in there somewhere or am i just being plain stupid. i have a haines manual that i followed and i cannot get the inner gears out to remove the rotor. can somebody help me please. if you want to mail me back at tgrantjr@adelphia.net to tell me what to do. thanx
[updated:LAST EDITED ON 24-Apr-02 AT 02:30 PM (EST)]I did my 85 Bronco last year, also with manual hubs and there as a C clip in a little groove on the inside of the hub and a snap ring on the end of the shaft. If it is all funky in the hub like mine was it can be a little hard to see the C clip. I pair of dental type picks were very useful in getting it out. You'll also need to get a spanner nut socket to get the two spanner nuts off that hold the hub on (hopefully I'm using the correct terms). Hope this helps.
