1978 - 1996 Big Bronco
Brake Problems
Old Apr 24, 2002 | 12:23 PM
loneranger7281's Avatar
loneranger7281
Brake Problems
i am having the problem of my life. my 85 bronco has bad rotors. it also has manual hubs. i took of the wheel and removed the cap from the hub. i took out the inner portion and the split ring from the axle. i cannot get anything to move. is there another ring in there somewhere or am i just being plain stupid. i have a haines manual that i followed and i cannot get the inner gears out to remove the rotor. can somebody help me please. if you want to mail me back at tgrantjr@adelphia.net to tell me what to do. thanx
Old Apr 24, 2002 | 01:24 PM
honney's Avatar
honney
Brake Problems
See link:
http://www.off-road.com/ford/bigbroncos/tech/balljoint.html
Old Apr 24, 2002 | 01:27 PM
map85's Avatar
map85
Brake Problems
[updated:LAST EDITED ON 24-Apr-02 AT 02:30 PM (EST)]I did my 85 Bronco last year, also with manual hubs and there as a C clip in a little groove on the inside of the hub and a snap ring on the end of the shaft. If it is all funky in the hub like mine was it can be a little hard to see the C clip. I pair of dental type picks were very useful in getting it out. You'll also need to get a spanner nut socket to get the two spanner nuts off that hold the hub on (hopefully I'm using the correct terms). Hope this helps.
Old Apr 24, 2002 | 07:03 PM
tomk89xlt's Avatar
tomk89xlt
Brake Problems
theres only one nut for each side. once you get it out, your rotor will pull off in one piece. grease your bearings!
Old Apr 25, 2002 | 08:10 AM
map85's Avatar
map85
Brake Problems
I swear mine had two, one with a pin on it and one that had holes in it that mated with the one with the pin. What am I remembering wrong?
Old Apr 25, 2002 | 05:41 PM
351Inside's Avatar
351Inside
Brake Problems
