Another starting problem!! iI bought a 75 f100 w/ a 300-6 % 3spd manual recently. Drove it home,really no problems then, besides lack of dash and reverse lights.and it does start without pressing the clutch. so far i replaced the ign. module,volt. reg.,starter solenoid, all batt. cables, battery, and clamps. Had the starter & alt. tested at the local parts store,they said they where fine. now i'm getting nothing but a clicking sound from the solenoid(relay).even with a batt. charger set to start it just clicks away. the only other thing i noticed is some of the wiring isn't exactly in the best shape, (the horn relay wires,and it looks to me the fusible links on the solenoidbut dont quote me on the links don't look burned out no wire showing). Without the charger, the headlights are bright,even the radio works, so what else is there???????????
Clicking solenoid usually means one of two things. Weak battery or bad solenoid. Other issues could be teeth missing from the starter ring gear. On a stickshift, the ring gear is replaceable. On an auto, the flywheel (flexplate) must be replaced. Faulty wiring a possibility too.
Have the battery tested by a shop to verify it's good. Since most new batteries are wet charged, they may sit around for years before they are used. So, just because the battery may be new, that doesn't mean it's any good. If the battery is completely dead, it will take a normal charger at least an hour to recharge it..a trickle charger takes much longer. You may have a short that's draining the battery. First thing---have the battery tested.
Well i have used the battery from 2 other running cars, so the battery probably isn't the case,i don't think it's the ring gear either, you don't hear the starter kick out at all.So i was thinking the same thing about the solenoid. well i guess it's off to the parts store again,try another solenoid. then on to the wiring issues. thanks for your help.
There are several different solenoids...take a good look at your old one, or take it with you. The difference is how they mount, and how many terminals there are. One has one terminal, the earlier models have two.
i normally replace all those parts when i buy a old vehicle, i have cleaned all connections put alittle oil on the posts. I'm thinking it the ign. switch not working properly. i unplugged the switch,and jumped the starter and it was ready to start.spinning over like a champ, but as soon as i plugged it back in---click,click,click.
I am by no way rich- but i have already replaced the one with a new one, bought another relay, thinking the first(new) one was bad. funny thing is i converted a fuel injection 4cyl mustang into a carbed v8 with less problems than this. i have owned the truck for about a month and a half and haven't put 20 miles on it yet. so tomorrow i will go out and try cleaning all connections, moveing grounds. this wasn't suppose to be a project truck till after other projects where done--but i will do the jumper check again-thanks.
sounds like the starter is locked up , mine does it ever once in a while and i can take it off and get it fixed for about $10 ...he takes it apart and buts all new bearings and stuff in it ...but im pretty sure thats yer problem ...i thought it was my selinoid to and i put 3 or 4 on it and it was the starter ....hope this helps
