1978 - 1996 Big Bronco
straight axle conversion
Old Mar 23, 2007 | 06:13 PM
streetbeast's Avatar
streetbeast
I need to know of a complete kit out there on the aftermarket that are good reliable kits for straight axle conversions with a dana 60. I know that people use d60's out of older fords from the 70s and early 80s but will a d60 out of a 96 f350 work?....Are they the the same axle? and what about a dodge d60 are thoughs the same?
-94 Bronco 351w-
Old Mar 23, 2007 | 06:34 PM
az4x4bronc's Avatar
az4x4bronc
on the dodge D60 the pumpkin may be on the driver side, may have to swap out t-case to make it work. BroncoGraveYard.com has the only axle swap kit that I know of. I have been running their kit for a couple of years and it is stout. the draw back with this kit is the radius arm brackets hang low. When I went from a 78 D44 to the D60 I had to put on a new track-bar. as far as a 93 axle i belive it would be easyer to do a leaf spring front axle swap with this axle.
Old Mar 26, 2007 | 01:16 PM
sprky's Avatar
sprky
go to www.fullsizebronco.com there a bunch of us who have done it without a kit
Old Mar 26, 2007 | 01:54 PM
Kemicalburns's Avatar
Kemicalburns
check out Cage, they are working on a kit as we speak. they should have what you need. check your pm
Old Mar 27, 2007 | 03:11 AM
fordman47201's Avatar
fordman47201
I have done a 81 bronco and used most of the stock buckets and brackets off of a 79 f-150 i had . you will have to amke a new steering arm due to the box on the opposite side of the frame , . I mounted my track bar into my frame rail because i broke my first mount off. you will also need to brace youre radiusarm drop brackets
Old Mar 27, 2007 | 08:04 AM
Kemicalburns
go to the place sparky listed, there is a spot dedicated to SAS swaps. there is 10 different ways of doing this.
Old Mar 30, 2007 | 01:56 AM
streetbeast
do you guys recommend using a one ton axle like a d60 or is that over kill.... i dont plan on being that agressive as far as wheeling it but have it mostly a commuter.....and what about that rear axle.....it being short would the angle be a problem as far as breaking u joints wheeling and vibrations. I've heard the 8.8 is a strong axle
Old Mar 30, 2007 | 08:28 AM
Kemicalburns
locate a hi pinnion D44 front and run a sterling 10.25 rear and your set. you can make an 8.8 strong but the cost vs buying the sterling wouldnt calculate you know what i mean. a D60 would be necessary if you plan on running 38"+ tires and wheeling it hard to boot. did you check out that other site?
