01 died. . . nostart
Well my buddies parents truck(01 250 PSD CC SB 4x4 AT) was driving home and i guess it decided that the parents needed to stop in at the local Red Ox restaraunt because it ran rough and died right next to it. My first thought was CPS. . . but it won't start again. They said the SES light came on. . . but I have yet to see it since. It cranks like crazy. . . fuel pump is audible, it is filled with Diesel I check the IDM relay. . . it works. No fuses blown. Something wierd here. I'm thinking it could be CPS or IDM. I've never screwed with the IDM on this engine yet. . . where is it? I'm thinking while my truck is down. . . I'll swap them and see if it works. Something else wierd is going on it with. . . I don't think its related but when you turn the Ignition on. . . wait about 7 seconds and the ABS box infront of the drivers side battery clicks and the motor spins for a split second. But it sounds like the bearing went out in it. Any ideas on any of this?
Tim
Tim
CPS, fuel
Well I cranked and watched the Tach. . . it moves so I believe the CPS to be good. I pulled out the fuel filter. . .t he bowl was full of fuel. . . and the filter looked ok. I don't have one to replace it so I couldn't try that. But seeing as how the bowl is full. . . I would assume that its still flowing fuel. I'm really leaning toward IDM. Is there any good way of testing that?
Tim
Tim
