Sponsored by: Auxito
catalytic converter
Old Mar 22, 2007 | 09:13 PM
ohiofordnut's Avatar
ohiofordnut
catalytic converter
hi i just put a complete exhaust on my 97f150 4.6 from the headers to the new h-pipe converters and catback but i took it for a ride when i was done and smelled something i just figured it was because it was new but i looked
under the truck and the passenger side cats were glowing red i cant figure it out
Old Mar 22, 2007 | 10:55 PM
thehawk789's Avatar
thehawk789
it is a bad cat, and it needs to be replaced.... wait... you said both? is there a hole in that side of the exhaust which is sucking in air and superheating the exhaust perhaps?
Old Mar 23, 2007 | 06:17 AM
projectSHO89's Avatar
projectSHO89
The cat probably isn't bad - yet....
You may have too much fuel being dumped in to the system and the unburned fuel is cooking off in the cats. This will melt them in short order.....
Common reasons are misfires, bad O2 sensors, or leaky injectors if the glowing cat is limited to only one side.
Steve
Old Mar 29, 2007 | 08:14 PM
ohiofordnut
Thumbs up catalytic converter problem ok
let me start by saying wow what a mess , put everything new on found out there was a short in the wireing harness , the # 3,#4 cylinder wasn't getting power all the time , then one of the new o2 censors were bad then i just tuned it up with original ford stuff runs just like it did when i brought it home from mullinax ford thanks for the helps PROJECTSHO89
ididntdoit89
Exhaust Systems
21
Jan 15, 2013 09:09 AM
kdokey
1997 - 2003 F150
Jan 11, 2010 09:46 AM
patt4you
25
Dec 16, 2009 12:10 PM
fairlaniac
1983 - 2012 Ranger & B-Series
16
May 27, 2008 08:40 PM
ohiofordnut
1997 - 2003 F150
Mar 22, 2007 06:12 AM
