1978 - 1996 Big Bronco
Code Help Please!!!!
Old May 3, 2002 | 08:06 PM
Bob_VT's Avatar
Bob_VT
Old May 9, 2002 | 07:15 PM
ryan cornell's Avatar
ryan cornell
Can anyone give me the fixes or possible fixes for these code's I'm getting on my 1993 302?
Code 55: Open connection in Keypower circuit or electrical charging voltage too low.
Code 56: Mass Air Flow(MAF) sensor or Vane Air Flow(VAF) sensor voltage signal too high, or Electronic 4-speed Overdrive Automatic Transaxle(E4OD)Transmission Oil Temperature(TOT)sensor signal voltage is too high.
Code 65: Electrical charging system problem occured-voltage too high(over 17.5 volts), or Engine control system never went into closed loop fuel operation, or Transaxle problem-Overdrive cancel switch(OCS) was not cycled during Engine Run self test.
This is a new short block(12,000 miles)in the truck now. The last motor detonated the 8th piston. I hear a little pinging now under de-accel and the accel. It lack's power sporadically also. The plugs are relatively white. I've put about 4,000 mile's on the new motor. I've replaced the alternator,PS pump,plugs,wires,rotor,cap,fuel filter,fuel pump,Knock sensor,starter. I've also deleted the emmissions crap. Any help or suggestion's would be greatly appreciated!!!Thanks, sorry so long. RYAN
Old May 10, 2002 | 03:23 PM
ryan cornell
No one has any idea's??
Old May 11, 2002 | 12:18 AM
proford460's Avatar
proford460
have you erased the codes and rechecked to see what re appears. are these code KOEO or KOER
Old May 11, 2002 | 08:07 AM
ryan cornell
[updated:LAST EDITED ON 11-May-02 AT 09:08 AM (EST)]>have you erased the codes and rechecked to see what re
I have not erased the codes, I'm not ever sure how to. The codes are KOEO. THANK YOU FOR THE REPLY! I just remember hearing the pinging before the last motor took a crap. Just don't want it to happen again. Also threw a fuel pressure gauge(autometer) on it, it read around 30 psi at idle and around 39-41 during accel.
Old May 11, 2002 | 08:47 AM
Big JOE's Avatar
Big JOE
To erase the codes, disconnect the battery for ten minutes. Then reconnect it and run the codes again.
Old May 11, 2002 | 10:40 AM
proford460's Avatar
proford460
make sure plug wires 7&8 do not run parallel this is what causes the 7-8 cross fire and engine failure follows recheck codes KOEO and KOER let me know
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
