Multy Grade Oil
confused So whats up Don
I would caution you that it would probably be a good idea to use one of the dual diesel/gas rated oils (Rotella, Delo, etc.) if you aren't already. On my 351M with about 15,000 miles on the rebuild, I am staying with Rotella 10w-30. With the concerns voiced concerning reduced additive packages in the SM rated oils, I don't want to take any chances on the flat tappet engine.
Towing, and climbing hills, you want your 351M-400 to work easier, not harder, correct?
Do you like your gas mileage in your truck? If so, a 10w30 will deliver peak possible MPG. 30HD oil, will knock that MPG down, if you like filling up sooner, with more trips to the gas station, then use a SAE 30HD oil. Me personally, I enjoy the best possible MPG when I add gasoline @ $2.20 -- $2.90 gallon. Maybe more maybe less where you live. But you get my point...
Good luck.
I'm going to stay with the 10 30. Gas here in Northern California Reg.3.09
Thanks for your reply Don
As an example, Texaco's 10W-30 full Synthetc's flash point is up there, like 396 F, with a 5% NOACK & .093% ash, so it can take the heat of that long mountain pull, no sweat!!!!
There are some mighty good synthetics on the market to choose from.
I just found some Synthetic Havoline at "Big Lotts" for $3 qt!!!!! It's going into the Ranger & Taurus, for their spring change out.
So why not consider a good 10W-30 synthetic for your towing, it'll take the heat, no sweat!!!! lol
Just another thought or two.
I want to do whats best for this truck.
I do have GeerVender over/under drive that make it a lot easier.
So you think I should switch? (WOW Did I open a can of worms) This is what I like about form. Any non mechanic can ask questions and get answers from guys that know.
Thanks again Don
I've heard talk about "synthetc" not sticking to metal parts as well as "regular" non synthetic "dino" oil.
So the theroy was that your engine would suffer more wear on start up, if you used "synthetic", because more would drin off the parts.
Don't think I've ever heard of a UOA that supports that idea.
Wonder why mfgrs of vehicles like Vettes & Vipers would use synthetic as factory fill, as they do, if that were so????!!!!
Some have said if you have some oil leaks or weeps, that they might get a little more "damp", because of the synthetics flow, penetrating, & increased detergency, causing those problem areas to act out more.
Or that we could have seal compatablity problems, that would cause leaks. Years ago Mobil did have some problems, but they are long gone history now.
I've not seen any problems switching from regular Havoline, to synthetic Havoline & back again, on my 99 Ranger 4.0L & 94 Taurus 3.8L & I'm ready to fill er up agan wih the Havoline synthetic I found on sale today, without any hesitation!!!!
If you choose a synthetic that is backward compatable with previous "S" service grades, you should be fine & your engine should iike it's new oil bath!!!!
I usually get between 1.8-2.2 better higway mpg, on the Ranger running between 55-70 mph & also tow mpg improvements, using synthetic 5W-30 Havoline, over their dino 5W-30.
Wasn't able to measure any "city" mpg improvements, over the two year period I used it, so I just went back to regular Havoline 5W-30, as the Ranger was rarely driven any distance on the highway, or towed any distance with it.
I wouldn't be afraid to try a good synthetic, in a backward compatable, specified service grade, for your engine. Do whatever makes you feel comfortable.
On Edit: I see in a previous post I listed a incorrect flash point value for Havoline 10W-30 synthetic, it should have been 496 F, instead of the 396 F value I posted. Danged good stuff!!!!
Just some thoughts to ponder.
Last edited by pawpaw; Mar 23, 2007 at 11:15 PM. Reason: correct Havoline flash point
Cars like BMW and Mercedes recommend extended OCI's, up to 15,000 miles or two years, with an oil life monitor system. Required oil changes are also included in the purchase price of the car, so non-approved oils will not be substituted during the warranty period. Most synthetics sold in the US do not meet European standards for those extended drains. I think Audi-Porsche-VW also have dealer-only oils for turbo models.
Since most American drivers and US-Japanese brand dealers seem stuck on frequent oil changes, there is no advantage for lower priced cars and trucks to have synthetic as factory fill. The GM oil life monitor system is a big step in the right direction, but how many owners and even dealers ignore it and go back to old habits?
Jim
Don
I used to run a single bypass filter (mount and hoses to install $25-30, filt $25-30) but with fuel injection I don't even run those now.
I run 20-25k all the time with no accessories.
