4 wheel drive problem
Old Mar 22, 2007 | 06:34 AM
konan's Avatar
konan
i tried to engage front drive last weekend and could not get it to work.dash lights for both high and low come on and i can hear a click when i turn the switch but no traction from front end.i had the hub lock engaged manully.thanks.
Old Mar 22, 2007 | 07:04 AM
AustinS's Avatar
AustinS
Do you get a click or clunk from underneath or just from the dash?
If from dash only, there is a problem with the gearmotor wiring or assembly.
If from underneath, there is a problem with the hub(s)
I'll send you a PM. E-mail me back and I'll send you the system testing info.
Austin
Old Mar 23, 2007 | 09:52 AM
elkarcher's Avatar
elkarcher
Austin, I am having trouble with my four wheel drive as well. Would it be too much trouble to get that testing info from you?
Thanks Elkarcher
Old Mar 23, 2007 | 02:25 PM
UcaN's Avatar
UcaN
Recently i could not get mine into 4wd..... without locking the hubs manually. The light would go on inside the cab and i could also hear a click but the hubs would not engage.
I checked the fuses and discovered a 10amp fuse was blown which activated the vacuum pump. That not only solved the problem with the 4x, but also my A/C vents as well.
#27 is the fuse......
Old Mar 23, 2007 | 05:11 PM
konan's Avatar
konan
i unpluged electric connection from pump and sprayed it and after replacing it 4 wheel drive engaged.is the hub on drivers side on ex supposed to be turned manually?i have never been able to turn mine.thanks.
