Valve Spring pressure
Old Mar 22, 2007 | 01:17 AM
92OldBlue's Avatar
92OldBlue
Post Valve Spring pressure
Could anyone tell me what the factory valve spring pressure is on a set of E7 heads? I am putting a performance hydralic cam in the truck and taking out the roller. The new hydralic says it requires a higher spring pressure but if the roller springs were already higher than what an orignal set of hydralic springs were, then I could leave the the hydualic roller springs in there right?
Old Mar 22, 2007 | 04:37 AM
HemiEater's Avatar
HemiEater
the best thing to do is have them checked......what cam are you going to use?
Old Mar 22, 2007 | 01:47 PM
92OldBlue's Avatar
92OldBlue
I am going to be using a Lunati Voodoo cam #61003 its .522 over .536 with 106 center line and 226 over 232 duration
Old Mar 22, 2007 | 03:06 PM
HemiEater's Avatar
HemiEater
you will need springs red line will be around 6500 with that cam
I got some Compcams single coil springs, retainers and locks I'll sell cheap.....I am haveing them check for seat pressure @ 1.80 install heigth (normal install heigth) and finding out where coil bind is.
I got them with a set of heads I bought and have no idea what the part number is. But I'll have the spring pressure in a few days....let me know if you want them.
75.00......
