Need More Info
Old Mar 21, 2007 | 11:45 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
Need More Info
Air Only Blows Out Of The Defrost Vents.
Have Read Here That It Could Be Vacuum Loss.
Looked Under Hood For Broken Or Disconnected Hose
But Did Not See Anything Obvious.
Could Someone Be More Specific As What To Look For
Thanx
03 F250 6.0
Old Mar 22, 2007 | 12:55 AM
bustech81's Avatar
bustech81
love to help but have no idea what truck you are working on. need way more info.
Old Mar 22, 2007 | 02:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Blend door motor could be bad, this will keep the correct door in the heater (plenum) chamber from opening. There are several on each truck. Please tell us what yr. and model truck you are working on, and whether it has a/c or not.
Old Mar 22, 2007 | 07:15 AM
projectSHO89's Avatar
projectSHO89
The "blend door" is only concerned with temperature control. There is a vacuum-operated diverter (several, actually) that controls all the airflow direction in the dash.
As you have a diesel, you have a separate vacuum pump that supplies the HVAC (and 4X4, if present) with operating vacuum. You will need to verify that the pump is operating and that it is supplying vacuum to the HVAC system. The supply line should be in the same place as the gassers, ie, right between the battery and the firewall. Inspect that particular line for damage, also.
Steve
Old Mar 22, 2007 | 10:03 PM
gb'sfx4's Avatar
gb'sfx4
The Truck Is A 2003 Ford F-250 Crew Cab Long Bed Four Wheel Drive Xlt With A 6.0 Liter Turbocharged Powerstroke Diesel And Yes It Has A/c
I Have Dual Batteries So Should I Be Looking At The Drivers Or Passengers Side ?
The Engine Compartment Is So Packed It Is Hard To Spot Something I Dont What I`m Looking For
Old Mar 24, 2007 | 01:37 AM
bustech81's Avatar
bustech81
You are correct in thinking that there is a loss in vaccum. when this happens this doors default to defrost for obvious reasons. does your truck have hydro boost, or vaccum boost brakes?
