1978 - 1996 Big Bronco
4 codes...not into diagnostics
Old May 24, 2007 | 10:57 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Originally Posted by bronk_richy
spout shows no signs of corosion. It does indeed have a great connection. I believe it is the pip sensor inside the distributor housing. Are there any other possible components causing this code? A trick?
I agree it's probably the PIP sensor inside the dist shorting out, or possibly one of it's wires (broken insulation?) grounding out. I'd change the sensor as a next step.....
Old May 24, 2007 | 12:08 PM
bronk_richy's Avatar
bronk_richy
thanks ranger!
