1978 - 1996 Big Bronco
Instrument Cluster Lights All Out
Old May 10, 2002 | 08:22 AM
Bob_VT's Avatar
Bob_VT
Old May 10, 2002 | 09:18 AM
bigbritbronco's Avatar
bigbritbronco
Post Instrument Cluster Lights All Out
Hi,
recently moved to the US from England and couldn't resist a big 1987 Bronco. It really is a good vehicle.
Problem is all the instrument cluster lights are out. Makes driving in the dark lots of fun!
Been told probably rheostat in headlight switch (unlikely all lights would go out at same time due to blowing). Any ideas where to get a new one? or if something else is likely the cause.
All help appreciated.
Graham
Old May 10, 2002 | 10:40 AM
Pilotrick's Avatar
Pilotrick
I know you probably already checked this but, did you check the dash light fuse? It is a 5 amp one if I remember correctly but, check the fuse block cover to be sure which one it is. If you already have done this then you need to buy the entire light switch if it is the rheostat. You can buy one at almost any parts store. Hope this helps,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old May 14, 2002 | 11:48 AM
bigbritbronco
Thanks,
Put in new switch & all is well.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
