High beam headlight problems
Old Mar 21, 2007 | 08:19 PM
paulcooper1969's Avatar
paulcooper1969
I'm having a problem with my high beam head lights, whenever I have the high beams on for about 3 min. or so my headlights start flickering on and off until I hit the high beem switch back to the off position.
I replaced the switch on the floor board but it did not help, I have had this problem with previous Fords and I just replaced the switch on the floor and was good to go, but not this time any idea's??????????
Old Mar 21, 2007 | 08:50 PM
Mil1ion's Avatar
Mil1ion
They don't make them like they used to.
The problem is Ford's design
They run full power thru the switch which evertually ruins the circuit breaker and causes it to connect --blow...rapidly.
Do yourself a favour and increase your headlight illumination by doing the relay upgrade.
It can be done in a day and is well worth the time & money
Then no more flickering lights.
http://www.northwestvintagebroncos.c...headlight1.htm
Old Mar 21, 2007 | 09:06 PM
paulcooper1969
You mean to tell me you just happened to have this information just laying around Dennis?
Old Mar 21, 2007 | 10:50 PM
big hoss 29's Avatar
big hoss 29
He usually does. And if he doesn't, someone else does.
Old Mar 22, 2007 | 12:10 AM
ryan f150 4x4's Avatar
ryan f150 4x4
i had the some prob on my 84 replace the dash switch. chack the plug on the dimmer switch mine was malted
Old Mar 22, 2007 | 05:49 PM
TUFFY's Avatar
TUFFY
I agree with what Mil1ion said. DO the relay upgrade. You won't regret it I haven't
