To be perfectly honest, it's marginal at best, at least has been for me. It's sort of the same thing a limited slip is doing, in theory, but obviously with different sized parts that aren't designed for it. For me, once I'm stuck, it's usually too late. Another thing, you can damage the brake parts with the e-brake engaged and giving it throttle. I know it can bend parts, the backing plates (I think it's the backing plates) on a Jeep
bought mine with out posi too got one on ebay for 250$$ install 300$$ would do it again makes big BIG diff dont know why any of these trucks leaves the factory with out
One other thing in re the e-brake trick...if you're using the brakes you're using the front brakes against yourself. The e-brake is only on the rear, so your front brakes aren't holding you back. This may be why it doesn't seem to work at all for some people. Don't use the brakes, use the e-brake.
Traction control isn't designed to fix open differential flaws. It is to prevent the driver from spinning their wheels in slippery conditions. You have cars with limited slip that have traction control.
Of course that is the main purpose, but it can be used to increase the traction of open diffs when combined with a 4 channel ABS system allowing each wheel to be braked independently; And it is being used by Nissan in thier Titan in this capacity.
An open diff always applies its power to the wheel with the least resistance. When you are stuck and not moving and one tire is spinning only, so obviously no power is going to the other wheel or it would be spinning too (dont cite the Ford LS here cause it slips excessivly and can be cured of that).
If you have 1 wheel with 1000lb of traction and the other has 100lb and then you apply 1000lb of braking to each wheel it will still spin the same wheel as it now has 1100lb of resistance to the 2000lb on the high traction wheel. Open diffs always spin the easiest wheel, if they didnt we would need LS & Lockers.
I will add that the E-Brake trick could work in rare situations, that being if the traction differential is minimal between the two wheels and the side that should be spinning has more traction such as the right wheel when trying to go forward.
Are you sure about that? My understanding of most active traction control systems is that they apply the brake on the spinning wheel, which will then transfer power to the one that isn't spinning. Kinda need an open differential in order to accomplish that. Seems like a limited slip would work against that.
It's only money; put in an ARB locker and don't worry about the parking brake or how much traction either wheel has<Grin>! Plus you get a decent little air compressor to air up with. I don't know about the effect on the warranty but it wouldn't be any different than adding an LS.
Having that huge 5th wheel would really make me lean to a locker than an LS. I used to get stuck towing my tag trailer in the sand. Now it isn't a problem. I did both axles with ARBs. This link has some good tips on airing down.
It's on the corvette. The main purpose of traction control is to prevent the driver from spinning out because of poor throttle control. Just like ABS is to prevent the wheel from being locked because of poor braking from the driver. Both aid in vehicle control because people cant drive. You see more cars with traction control then trucks. The corvette never goes off roading, so why would the corvette be worried about getting stuck? Simply, because traction control is to help driver with throttle control and aid traction, and not to help him get unstuck in a 3 foot mud hole.
