My check engine light came on a few days ago so I decided to get the codes read (usually I would tinker and then reset the computer but.....)
Anyway I went down to one of the local parts stores and asked if they would read the codes.
The fellow had an OBDII scanner on the shelf which he gave to me and I went out to the lot to read the codes.
It wouldn't scan the truck so I went back in and he came out and tried.
Same thing, the device read "ErPr".
I thanked him for his time and went to another parts store on the way out of town.
Same thing. The device does not react in any way being hooked to my truck.
So I reset the computer (and waited a couple of minutes at idle) and drove home.
The idle had settled down as it was jumping around a bit this winter and the light is off.
I have never had a diagnostic plug fail on any of my vehicles.
Is there some special trick to this 1999Ford?
The so-called "heavy-duty" vehicles were exempt from that date. My '97 F250 with a 460 was pure OBD-I with the connector under the hood and everything. The early Super Duty was more like an OBD-I system with an OBD-II connector. If you look at the emissions sticker under the hood, it'll probably still say the vehicle is OBD-I... at least I think my '00 model did.
The sticker under the hood states my truck is compliant with all Canadian and U.s federal emissions laws for heavy duty engines.
Makes no mention about being OBD I or II.
But the info on one of the previous links says my truck should be OBD I with the same connector as the OBD II trucks so the scanner should be able to link to my truck. And this is the problem I'm having as it will not link.
I am going to borrow an OBD I scanner this weekend to see if it will link up.
The OBD I scanner has a different plug so this particular one will not work.
The local Canadian Tire parts store says only a dealer can read it because this truck has an OBD II diagnostic port.
Has anyone had codes read with a handheld aftermarket scanner?
Seeing as I can't buy or borrow one a dealer scan is my only option.
And at $90 an hour.....ouch!
I have a 07 SD V10 and mine had the check engine light come on, and I used my OBDII reader and it also did not connect to the system. Truck is under warrenty so it went to the dealer. I also thought that this was an OBDII truck, I think the OM says that also. Forgot to ask the dealer what was up with that, I may need to go back to get that info.
Jeff
05-up is CAN - Car Area Network - there's lots lots more "stuff" in there... I don't think the hand-held off-the-shelf scanners would work with it. Much like the '99 V10, apparently...
My '01 X w/ V-10 read just fine using the scanner at Checker Auto. It was an AutoXray product.
My dash has an OBD-II style connector. As to the OBD level of the PCM itself I can't guess.
The scanner did report some tests or data "not supported" but it did fine reading the generic codes.
I don't know if any of the cheap/simple hand held scanners will read the manufacturer specific stuff that is outside the realm of "generic" OBD II, but they should at least connect.
